Is it possible to put 18x9.5 on all four corners?
I found a good deal on some wheels, but they arent staggard like stock. They are all 18x9.5. Can I run these without messing anything up? If so what tire sizes should I run?
they might not fit in the front without rubbing suspension parts... depends on offset and spacing behind the wheel
if they do fit, you can run 245/40 front and 275/40 rear with no problem... although the 245/40 may be a tad narrow for the 9.5" wheel
the stagger aplies to tire sizes... not wheel sizes... the Performance model has 18x8 front and rear, but has 225/45 front and 245/45 rear tires...
Hope that helps,
PeteH
Hope that helps,
PeteH
MAsSIVrOOM
Oct 20, 2023 10:50 AM
