Tire fitment of 265/40/18 front and 305/30/19 rear
Old Jan 29, 2012 | 02:00 PM
saysangil's Avatar
saysangil
thx for all the input guys!!!
hows 285/40/19 on the rear sound guys???
and still have 265/40/18 on the front
Old Jan 29, 2012 | 02:23 PM
terrasmak's Avatar
285/35-19 rear would probably work fine with that front.
Old Jan 29, 2012 | 04:01 PM
TehkMob's Avatar
TehkMob
Why do you want so much tire? That's my question, is there a goal or a purpose? Or just because? Just curious.
Old Jan 29, 2012 | 04:06 PM
saysangil's Avatar
saysangil
I actually got pretty good deal on tires and I bought it without thinking to be honest...and I'm trying to fix the problem...lol
Old Jan 29, 2012 | 04:14 PM
Waiz's Avatar
Waiz
Originally Posted by jerseystyle
40 series up front is stock. The better question is why go with a 30 in th rear? I'd stick with a 265/40/18 up front and a 285/35/19 in the rear.
Old Jan 29, 2012 | 04:17 PM
dkmesa350z's Avatar
dkmesa350z
What's your point? The size the OP stated were way off. (see Davidv's chart). A 305/30/19 is actually thinner then the stock 265/35/19. The OP asked for advice and I gave it to him. My advice was if he wanted beefier tires. But wanted to stay close to a stock ratio.
How is someone giving advice on a subject they are confused about helpful in any way? You're still missing it...the aspect ratio measures the ratio of sidewall height to width. A wider tire with the same aspect ratio will result in a wider sidewall and taller diameter.
Old Jan 29, 2012 | 04:29 PM
KingBaby's Avatar
KingBaby
Hardest Setting
I think both sides are confused mainly due to the OP!
I fault the OP in this one!
OP are you still at stock height? Is this on the stock wheels? Endly is this for looks or performance?
Old Jan 29, 2012 | 04:48 PM
jerseystyle's Avatar
jerseystyle
Who's confused here? You are absolutely correct but when did I every say differently? Like I stated, a 305/30/19 has a SMALLER side wall than the stock 265/35/19 and he wanted to go with a 265/40/18 up front, causing his front wheels/tires (as a whole) to be taller then the rears. I have a great idea, since you are the expert here, how about you give him some of your advice? I'm sure we ALL could learn so much from you!
Originally Posted by Waizzz
I guess we're both confused, huh Waizzz?
Old Jan 29, 2012 | 11:59 PM
285/40/19: Actual speed 100.0 MPH. Speedometer will read 94.02 MPH.
I can provide you with the tools to make a proper tire selection, but if you do not use them I may as well be talking to a brick wall.
Old Jan 30, 2012 | 05:49 AM
saysangil's Avatar
saysangil
so u mean I should go with 285/35/19 on the rear and stay with 265/40/18 on the front right?
Old Jan 30, 2012 | 08:37 AM
jerseystyle
You smell that? I smell TROLL. No one could possibly be this impossible to get through to.
Old Jan 30, 2012 | 10:39 AM
saysangil's Avatar
saysangil
please don't make me figure things out
just suggest something with good backup lol
I'm planning both autocross and some track time during summer and I talk to one of my
friend and he told to to stay with same section height.
so my final decision is to stay with 265/40/18 on the front and get a set of 285/40/19 in
the rear.
response please and thanks
Old Jan 30, 2012 | 10:47 AM
Waiz's Avatar
Waiz
OP don't be lazy
We already gave you enough suggestions
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
