Tire pressure sensor?
Old Feb 29, 2012 | 01:24 PM
Toasterflyer's Avatar
Toasterflyer
Default Tire pressure sensor?
Just took delivery of an '08 Nismo and noticed the tire pressure sensor light is on. I was just wondering how sensitive it is. I have not checked the pressure in each tire yet. This is just a general question. The car is headed to the dealer to get a multipoint inspection etc.
On that note I do know there are valve caps that change color depending on tire pressure loss.. good idea? If so, recommended brand??
Thanks
Rich
Old Feb 29, 2012 | 01:58 PM
fhumphrey04's Avatar
fhumphrey04
Going forward you should probably research this before making a new thread, and additionally this is not only specific to the Nismo. There's a ton of threads on this very issue.
Anyways- your tires should be at 35 psi per corner to meet the factory specs. Once that's done your TPS light should go away. Mine has been on pretty much since I got the car a year ago and nothing seems to make it go off, so I've just accepted it and check my tires the tried and true way: manually.
Old Feb 29, 2012 | 02:35 PM
122554's Avatar
122554
New Sensor
Old Feb 29, 2012 | 03:02 PM
zero_shift's Avatar
zero_shift
I got a spare pressure sensor, if interested pm for price.
Old Feb 29, 2012 | 03:22 PM
Lakeside's Avatar
Lakeside
Being that you live in the Northeast, the salt has most likely damaged/corroded the sensor! You will need a new one or one's! Not cheap either... The steelership will rake you over.
Old Feb 29, 2012 | 03:44 PM
122554's Avatar
122554
Buy here.
http://www.revolutionsupply.com/TPMSIndex.aspx
Work great!
Old Feb 29, 2012 | 05:18 PM
jv350z's Avatar
jv350z
Originally Posted by 122554
Oro-Tek sensors work OK?
Old Feb 29, 2012 | 07:07 PM
terrasmak's Avatar
check your tire pressure, it takes about as long as it does to make the post you did.
Old Feb 29, 2012 | 09:40 PM
Waiz's Avatar
Waiz
https://my350z.com/forum/wheels-and-...onitor-tp.html
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
