will my 18" infiniti wheels fit on my 350z?
the tires on the infiniti wheels come staggered. The rims actually are not, they are all the same.i've always put on all the same tires so i can rotate normally....will there be any problems?
Infiniti wheels are not staggered. The ones I have anyways. The tires come staggered on them tho. But when I bough new ones I bought them all the same size so I could rotate Better. I had. No use for staggered
The wheels will be OK. I believe width and offset are similar to 350Z OEM wheels.
On my old g sedan (idk if that makes difference) the back tires were wider than the front. But the rims were all the same. I ended up putting the same all around so I could rotate front to back.
Also what do you guys pay for a set of tires? I wanna take off my Z's stock 17's and put on my oem18's off Infiniti
https://my350z.com/forum/wheels-and-...ml#post9638722 didn't you ask the same thing here? i bet the answer is still the same.
For those that dont believe that my g35 wheels are not staggered....look it up
???I'm trying to understand what you are asking...
First,the wheel&tire set up on your Z is staggered.
The rear TIRE(not the wheel)is taller than the front(about 1/2").
The rear wheel is a bit WIDER than the front.The added width
of the wheel has to do with having a slightly larger tire in the rear.
Since you have 17's,I'm thinking you have a 03-04 Z.
What is your objective?
I don't recommend the Infiniti wheels&tire on your Z.
What tires cost?Depends on the size 17-18-19-20.
Depends on the brand.Obviously,the larger tires-19's
for example are gonna cost more.I'd start with about a grand
for a decent set of tires.
if that helps.
