Enkei/Tenzo? - need advice for offset
Old Mar 18, 2012 | 07:16 PM
swat518's Avatar
swat518
Default Enkei/Tenzo? - need advice for offset
Wanna get a bigger wheel, Appreciate if anyone can give an advice?
2003 base.
Candidate 1: Tenzo type M
F - 19*8.5 offset +17
inner clearance comparing with OEM: same
outer clearance: +26mm
R - 19*10 offset +22
inner clearance: -14mm
outer clearance: +36mm
Candidate 2: Enkei Raijin
F - 18*8.5 offset +35
inner clearance: -18mm
outer clearance: +8mm
R - 18*9.5 offset +15 /;;;;+35
inner clearance: -1mm ;;;; inner clearance: -21mm
outer clearance: +37mm ;;;; outer clearance: +17mm
I did research in the site, but not able to find the answer. wondering if the offsets are fit for my 03 base?
Thanks in advance!
Old Mar 18, 2012 | 08:32 PM
Waiz's Avatar
Waiz
You're good on either specs, choose your favorite from the two
Old Mar 18, 2012 | 09:19 PM
terrasmak's Avatar
2003 base.
[U]R - 18*9.5 offset +15
I did not research in the site, cause i was not able to find the answer. wondering if the offsets are fit for my 03 base?
Thanks in advance!
Fixed it for you, either of those will work great front and rear. Tenzo is a complete and total crap wheel , so Enkei would be my choice.
Old Mar 19, 2012 | 08:07 AM
swat518's Avatar
swat518
Thanks Terrasmak.
Can you please specify for rear Enkei offset, which should I go for, +15 or +35?
some guys said Tenso is low-end wheel, some said it is good. Appreciate if you can tell what's the difference between these two brands?
Thanks!
swat518's Avatar
swat518
Appreciate ur promoptly reply!!
Old Mar 19, 2012 | 11:51 AM
sry110's Avatar
sry110
The +15 offset will be aesthetically better since it pushes the outside of the wheel farther out from the center of the car. Meanwhile a 9.5" wide wheel with +35 offset will be considerably swallowed up by the Z's rear wheel wells.
Old Mar 19, 2012 | 02:16 PM
terrasmak's Avatar
+15 is the wheel you will want.
Old Sep 15, 2012 | 11:41 AM
liQUidSkYZ's Avatar
liQUidSkYZ
Default which rim u have on your car now?
im doing some research on raijin too.. if u bought raijin 18x8.5 +35 & 18x9.5 +15, what size of tire u wrap them with?
Old Sep 15, 2012 | 12:05 PM
ZS14RR's Avatar
ZS14RR
Neither
Old Sep 15, 2012 | 12:22 PM
sofa king's Avatar
sofa king
8.5 wide? fail
Old Sep 15, 2012 | 01:27 PM
liQUidSkYZ's Avatar
liQUidSkYZ
Originally Posted by sofa king
8.5 wide? fail
Originally Posted by ZS14RR
Neither
from what i understand so far
front 18x8.5 +35
rear 18x9.5 +15
is what recommend to swat518
if u said "neither" & "8.5 wide is fail" then i should go with 18x9.5 +15 all round?
Old Sep 15, 2012 | 01:31 PM
Bmurray350z's Avatar
Bmurray350z
If it were me, i'd do 18x9.5 +15 all around, add 10-15mm spacer in the rear. and tire sizes.. there are a lot of options. I'd probably do 255 in the front and 275 in the rear.
Terrasmak knows tires a lot more than me.. let him tell you, lol.
Old Sep 15, 2012 | 01:48 PM
liQUidSkYZ's Avatar
liQUidSkYZ
back in march the threat stop when terrasmak mention that +15 is the whell u want...
i got confuse
got cha 18x9.5 +15 all round but need to add 10-15spacer in the back
what is the reason for add spacer in the back? is it just because of the look-bigger lips-deeper concave?
**for example** comparing [18x9.5 +15 with 20mm spacer] & [18x9.5 +35]
both will have the same flushing widith at the rear fender the only different is +15 offset rim will look better
Old Sep 15, 2012 | 02:00 PM
TheFknBoss's Avatar
TheFknBoss
+35 in front? Wtf your gonna need a 10mm spacer min to bring it out to the fender go 15 all around if possible or do a square setup
Old Sep 15, 2012 | 02:02 PM
TheFknBoss's Avatar
TheFknBoss
With those tires sizes you'd run 225 255
Old Sep 15, 2012 | 02:23 PM
terrasmak's Avatar
Just grab 9.5 +15 for front and rear, mount some 255/40 up font and 275/40 on the back. You may want a small spacer for the rear , depending on your liking.
Old Sep 15, 2012 | 02:53 PM
liQUidSkYZ's Avatar
liQUidSkYZ
18x9.5 +15 all 4 rims
front 255/45/18
rear 275/40/18 + 15mm spacer
shopping time
Thank you--->terrasmak-thefknboss-bmurray350z-sofa_king-zs14rr
Old Sep 15, 2012 | 03:07 PM
sofa king's Avatar
sofa king
@ least 9.5 8.5 looks good on the G sedan but not a Z.
spend more time in the enkei thread and look at what other guys are running to see what fits your style.
liqalu04
Jan 2, 2022 12:58 PM
