Rays Valve Stem & Stock TPMS Compatible?
Old May 26, 2012 | 07:52 AM
benwa02's Avatar
benwa02
Default Rays Valve Stem & Stock TPMS Compatible?
Anyone know if the rays valve stem set would work with the stock TPMS? (2006 Base Z)
http://www.evasivemotorsports.com/mm...w=&range_high=
I've read mixed reviews on whether they work for some TPMS or not... haven't seen specific Z comments with stock wheels.
I'm painting my wheels and looking for something in black that would blend in.
Thanks.
Old May 26, 2012 | 09:34 AM
benwa02's Avatar
benwa02
Damn.
Thanks for the info!
Old May 27, 2012 | 10:13 AM
Waiz's Avatar
Waiz
https://my350z.com/forum/wheels-and-...onitor-tp.html
Q: Will the sensors fit this wheel?
A: It depends. They fit on forged or cast one-piece wheels in which the valve stem is aligned in a similar fashion (angled) as the OEM wheels.
They usually don't fit multipiece wheels or wheels where the stem is perpendicular to the wheel barrel.
They definitely fit:
18" & 19" OEM wheels
Nismo LMGT4
Volk LE/TE37, CE28N. They will fit the Volk GTS but sensor must point "up" toward tire.
PIAA Rozza (adapter available from Z1 Performance)
They can be made to fit almost any other wheels with the "banding" method, described in these three threads:
https://my350z.com/forum/brakes-and-suspension-diy/186197-how-to-make-your-own-aps-tire-bands.html
https://my350z.com/forum/brakes-and-suspension-diy/30147-designed-a-way-to-mount-tire-pressure-sensor-to-any-wheel.html
https://my350z.com/forum/brakes-and-s...s-sensors.html
