VMR V710 Thread
Old Sep 26, 2013 | 12:36 PM
  #61
chrisrefaei's Avatar
chrisrefaei
Do the 19s and tires close up the wheel wells pretty well, with out a drop?
Old Sep 26, 2013 | 02:31 PM
  #62
sry110's Avatar
sry110
No. In fact, without a drop it could look worse than stock. Lower offset than stock means the tire is pushed closer to the fender, meaning that the tire-to-fender gap can actually become more apparent.
If the tires are sized properly, their outer diameter (rolling diameter) should be very close to the OEM tire rolling diameter. This means little to no change in the tire-to-fender gap in the vertical direction. Meanwhile, the 19" tire will have a shorter side profile (side wall) than the stock 18" tires, because the wheel is 1" larger in diameter.
The combination of adding relatively wider and/or lower offset 19" wheels and tires without lowering the car will likely lead to the "4x4" look that various members here have been flamed for having. I happen to agree that the car should be lowered first, then wheels and tires upgrade, assuming you are planning to do both at some point and it has to be done in series instead of at the same time.
Old Sep 26, 2013 | 04:09 PM
  #63
chrisrefaei
Originally Posted by 727FL350z
What do you guys think about a set of VMR v710's with 19x9.5/19x11: Hankook Ventus V12 evo K110 package on a 350z? (Not the most expensive wheels i know, but currently a student) Do they look good with the car? I would be going with a white Z and matte black wheels.
Let me hear your opinions so i can make a choice!
Is this black 350z dropped aswell?
Old Apr 23, 2014 | 11:32 AM
  #64
chrisrefaei
Default Need Help With Picking VMR 710 Wheels
I'm going with 19 x 9.5 in the front and the rear will be 19 x 11 I'm wanting to go with a very nice Concave look. Little concave in the front and a reasonable nice concave in the back. I need help with which finish to go with on my Silverstone 350z. The colors are Hyper Silver, Gunmetal, Matte Black I can't figure which to go with. Also The P.C.D should be 5 X 112 correct?
How my Z looks:
Hyper Silver,
Gunmetal,
Matte Black
Old Apr 23, 2014 | 12:07 PM
  #65
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
5x114.3 not 5x112.
Old Apr 23, 2014 | 12:15 PM
  #66
chrisrefaei
Originally Posted by AdvanZ33
5x114.3 not 5x112.
Thank you for the correction
Tochigi_236
Sep 27, 2015 03:40 PM
