Problem With Tires
Old Jul 6, 2012 | 06:32 PM
BipJip's Avatar
BipJip
Default Problem With Tires
I have a 07 350zr. i bought 255 45 r18 tires for the rear and it feels like the side wall is breaking down to easy. i had a 4 wheel alignment after, and they told me the rear toe was out of spec so i had them align it straight. i have factory v2 rims. should i have gone with a 255 40 r18?? or did he align the tires wrong? idk if this is normal when you go from a 245 45 r18.
Old Jul 6, 2012 | 06:36 PM
mattleegee's Avatar
mattleegee
what tires?
Old Jul 6, 2012 | 06:37 PM
Frosty87's Avatar
Frosty87
What's tire pressure.. also the added sidewall will flex more.
mr. sparco's Avatar
mr. sparco
Brand and type of tire might help. BTW it's Injen not "injin."
Old Jul 6, 2012 | 07:23 PM
silverbullet_Z's Avatar
silverbullet_Z
You mean all tires aren't the same??? What????
Old Jul 6, 2012 | 07:59 PM
bboypuertoroc's Avatar
bboypuertoroc
First problem is those skinny *** tires for the rear. Second issue is prolly the tire itself. Third, check the pressure.
Old Jul 6, 2012 | 08:16 PM
eat rice z33's Avatar
eat rice z33
Did you buy firestone indy wide oval 500?
Old Jul 7, 2012 | 05:12 AM
BipJip's Avatar
BipJip
they are Yokohama AVID ENVigor (W-Speed Rated).
Old Jul 7, 2012 | 05:36 AM
BipJip's Avatar
BipJip
the pressure was 33 lbs. now its 43 lbs like the front.
Old Jul 7, 2012 | 08:34 AM
Spork's Avatar
Spork
Are all tires the same brand and model? Correct stagger? Correct size? A popular thing is to drop the sidewall aspect by 5 all around. Some tires just have a mushy sidewall, may just have to get used to it.
Old Jul 7, 2012 | 09:09 AM
JCITY's Avatar
JCITY
regular street driving..35lbs all around
Old Jul 7, 2012 | 10:58 AM
mr. sparco's Avatar
mr. sparco
43 is quite high.
Old Jul 7, 2012 | 01:44 PM
mattleegee's Avatar
mattleegee
im a 31-33psi person myself, that is what i was taught the first day i owned a car so i have stuck with it, never heard above 40psi..... interesting
Old Jul 7, 2012 | 03:02 PM
Italianjoe1's Avatar
Italianjoe1
Lower the pressure to 35 or so psi, and put a couple miles on them. Those tires aren't that stiff, but I doubt you are rolling the sidewalls over. See if they still feel funny after 2-300 miles. I had a set of hankook V12's that did that to me, the rear of the car felt really loose until they wore in a bit.
Old Jul 7, 2012 | 06:06 PM
Waiz's Avatar
Waiz
What do you mean by "handling like crap"? explain this and what size are your fronts?
Read this post for reference regarding correct OEM sizing:
https://my350z.com/forum/4936171-post42.html
Old Jul 9, 2012 | 11:32 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
43 is quite high.
+1
43psi is really high. Lower the psi, drive around a bit, see if it changes anything.
Old Jul 10, 2012 | 09:59 AM
neal@tirerack's Avatar
neal@tirerack
Pix would help out if you have any.
Uriyo_
Sep 8, 2021 08:46 AM
