TPMS differences
Old Jul 19, 2012 | 07:59 AM
carlosdurrah's Avatar
carlosdurrah
Default TPMS differences
does anyone know if there is any reliability differences between these two types of TPMS? I need to replace the ones in my 03. i think they are both made by the same company.
Attached Thumbnails TPMS differences-oe-dg-tpms-1-1-.jpg   TPMS differences-st037k-2-1-.jpg
Old Jul 19, 2012 | 08:36 AM
DavesZ#3's Avatar
DavesZ#3
Because they are made by the same company doesn't mean that they work exactly the same. Just as the 370Z sensors don't work in the 350Z, those may be electronically incompatible.
Old Jul 19, 2012 | 10:48 AM
Shop TPMS's Avatar
Shop TPMS
Vendor - Former Vendor
From the picture, it looks like the first set are Schrader EZ sensors, which are a universal programmable sensor. The second picture is from us which are OEM made by Schrader for Nissan. Personally I dont like to mix and match, but they should work the same as a set.
Old Jul 19, 2012 | 11:28 AM
carlosdurrah
ok. thanks. I will just go with the OEM set
Old Aug 8, 2012 | 05:51 AM
Gerry's Avatar
Gerry
Can I ask where you got your OEM sensors. Im in the same boat with my '03. I want OEM cause I know they will fit in my SSR rims.
Old Aug 8, 2012 | 07:04 AM
122554's Avatar
122554
What type of SSR? When I put them on mine, I had to use the bands that go around the middle of the rim.
Old Aug 24, 2012 | 03:00 PM
Shop TPMS's Avatar
Shop TPMS
Most have either strapped (as in your case) the sensors or have drilled into the barrel to either mount an adapter or tpms valve plug. As far as we've seen and have mounted, these are the only ways.
We're working with SSR USA, in order to see if we can make the US market wheels Tpms friendly. Hopefully, something will come of our joint efforts.
350z82
Oct 1, 2015 06:25 PM
