Is there a way to Determine Offset from Camber?
Old Oct 15, 2012 | 10:05 AM
dmorrow's Avatar
dmorrow
Default Is there a way to Determine Offset from Camber?
I have wheels on my z33 that I do not, for now, know what offset they are.
I'm wondering if there is a way, with the camber degree that I have right now, how do you find out what offset wheels to get to basically correct the camber??? i may not have said that correctly, but hopefully..im really hoping...i can get an answer that doesn't include the 50 post saying SEARCH!!!?!?@#%#
thanks for any input, (thats useful)
Old Oct 15, 2012 | 10:19 AM
Bmurray350z's Avatar
Bmurray350z
have you checked the backside of the wheel? a lot of times the specs will be engraved there or something
Old Oct 15, 2012 | 10:29 AM
Phenom's Avatar
Phenom
Toasty
I don't really understand your question. What does offset have to do with correcting camber?
Old Oct 15, 2012 | 02:38 PM
JCITY's Avatar
JCITY
Maybe a pic of the wheels on your car,a front view,would allow a "a guesstimate"
from a forum member.
What does camber degree have to do with the offset?
I'm missing something.
Old Oct 15, 2012 | 02:48 PM
KingBaby's Avatar
KingBaby
Hardest Setting
I can wait till teleportation is possible....
OP: I need help
Me: I can help better in person
Me: invite me
OP: OK
OP: why'd you slap me
Old Oct 15, 2012 | 03:07 PM
Waiz's Avatar
Waiz
There is no way to determine offset without either looking around the wheel for markings or taking it to a professional to measure it
Old Oct 15, 2012 | 06:24 PM
bmccann101's Avatar
bmccann101
combine all answers left thus far together into one sentence and youre money, OP.
Wheel offset correcting camber? uh.. no.
We cant tell you to search if what youre saying makes no sense.. its as logical as ...uh..
questioning the current marital status of the numeral 5.
Unrelated, makes no sense. Sorry, not hatin. jussayin
Old Oct 16, 2012 | 09:03 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
+1
OP - Take the wheels off and look for the markings on the back side of the wheel for the offset. Or you can measure if there are no markings.
https://www.rsracing.com/tech-wheel.html
Old Oct 16, 2012 | 12:14 PM
AmateuRN's Avatar
AmateuRN
Someone needs to learn what offset is, lol.
You could google how to measure offset, OP, and do it yourself and get *pretty* close to what it is... would be more accurate then people guessing just by looking at the mad tyte stance.
Old Oct 17, 2012 | 02:46 AM
-Trav-'s Avatar
-Trav-
OP what are you trying to do exactly? If youre trying to find out how much more negative offset you need to fill the gap you currently have, you gotta take the wheel off and check the markings, or just measure it out.
As far as correcting camber with a different offset wheel, that is impossible.
Old Oct 17, 2012 | 12:26 PM
driftsucky's Avatar
driftsucky
Don't listen to all these noobs OP. It's very easy to determine the offset from camber. It's not an EXACT calculation, but it'll get you close..probably within mm's. Here's what you wanna do.
1) get the car to an elevated position.
2) You're going to want to measure the point where the strut and spring meet. It should be between 2 and 3 inches celcius.
3) multiply that by 7.
4) Look for the markings on the wheel. If there are none, you're going to have to remove the wheel.
5) Measure the distance between the mounting point and the center of the wheel in inches. Write that number down.
6) Convert that number to mm.
7) Start at number 5 cuz the rest of that is jibber-jabber.
Whatever you're trying to DO, you can't do it. But with this info, you're ready for
Old Oct 17, 2012 | 01:03 PM
dvo's Avatar
dvo
How to measure offset
Correct way to measure width
Old Oct 17, 2012 | 01:54 PM
AroundMyHorn's Avatar
AroundMyHorn
Old Oct 17, 2012 | 03:06 PM
driftsucky's Avatar
driftsucky
That is the most useless post I've ever seen on the internet ever. I love it.
Old Oct 17, 2012 | 04:30 PM
Phenom's Avatar
Phenom
Toasty
You forgot to divide inches celcius by torque in step 2.
And you can skip step 6 if you just use a metric ruler.
Old Oct 17, 2012 | 06:37 PM
Esser's Avatar
Esser
I'm sure if you posted a pic of the rear of your car with some suspensions specs, we could guess your offset within 5mm. Some of us study this a little too much on here lol
Old Oct 17, 2012 | 06:55 PM
jennifhanlon's Avatar
jennifhanlon
Rowlett
Misc.
Oct 2, 2015 10:38 AM
