Toyo R888's on stock 350Z wheels
Old Dec 16, 2012 | 10:50 AM
Mike Anthony's Avatar
Mike Anthony
Default Toyo R888's on stock 350Z wheels
I'm sure this has been discussed here before, so if it has I'm sorry. I searched the forums, the Internet, etc.
Stock 2007 Nismo wheels are
Front 245/40-18
Rear 265/35-19
I can't find exact match R888's, and I know nothing about wheel size and fitment. Is there another size R888 that would fit on my stock wheels with no problems?
Thank you for the help!
Old Dec 16, 2012 | 12:28 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
265/35/18 front
295/30/19 rear
Old Dec 17, 2012 | 04:48 AM
Mike Anthony
Is there anything I should know about using a wider tire? And issues or other things I need to do to make it work?
Old Dec 17, 2012 | 05:28 AM
350zsunshinefl's Avatar
350zsunshinefl
advanz33 nailed it.
only thing different is you will have more lateral grip, lose a few MPG's.
Old Dec 17, 2012 | 06:38 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Why do you want Toyo R888 tires? With question like above questions me why you want a R-Compound tire.
Old Dec 17, 2012 | 06:52 AM
C5_vette's Avatar
C5_vette
R888's have a very limited lifespan if used for street use, as well as a narrow temperature range.... are you sure these are the right tires for you..
Old Dec 17, 2012 | 08:27 AM
DankZ07's Avatar
DankZ07
back up a step, and ask what tires to run before you worry about size.....robert nailed it..
Old Dec 17, 2012 | 08:31 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
It says he's a "Know It All."
Old Dec 17, 2012 | 08:44 AM
AdvanZ33's Avatar
AdvanZ33
I thought that was a default title for all you PM members...I've seen it quite a bit.
Old Dec 17, 2012 | 06:46 PM
Mike Anthony
"Know it all" is default. If it isn't, I sure didn't put it there. Hah
Lets just say I've got some plans for this car - but I don't know much about what I am doing yet. Thus I am trying to learn. Thank you guys for the info!
Old Dec 17, 2012 | 07:19 PM
terrasmak's Avatar
Do you have plenty of track experience , if not , stick to normal street tires while learning.
Old Dec 17, 2012 | 07:25 PM
Mike Anthony
I do not, but I was hoping to get some.
Old Dec 17, 2012 | 07:41 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Learned while the car is hard to control, than work up to sticky tires.
Old Dec 19, 2012 | 05:53 AM
Mike Anthony
Makes sense to me. What brand street tires would you suggest? Price isn't an issue for the most part and I would prefer something grippy.
Edit: thoughts on Yokohama Advan AD08?
http://www.tirerack.com/tires/tires.jsp?tireModel=ADVAN+Neova+AD08&tireMake=Yokohama
Old Dec 19, 2012 | 06:13 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
AD08 are another DOT R-Compound. I really liked the BFGoodrich KDW tires.
Old Dec 19, 2012 | 06:42 AM
terrasmak's Avatar
Hankook RS3, but i suggest something like a Hankook V12 for your first few trackdays and work up to an RS3.
Old Dec 20, 2012 | 09:55 AM
SE5spd's Avatar
SE5spd
AD08 is a 180TW street tire.
OP - you can either start off on something like nitto invo, hankook V12, etc
Or star spec, rs3 etc. my first track day was on RS3s.
Old Dec 20, 2012 | 11:51 AM
CH@Dbee's Avatar
CH@Dbee
I run Goodyear Eagle RS-A all season tires.....it forces you to learn car control and be a better driver.
Old Dec 20, 2012 | 12:11 PM
P&K350Z's Avatar
P&K350Z
Surprised no one has recommended Bridgestone RE11s
Old Dec 20, 2012 | 01:03 PM
SE5spd's Avatar
SE5spd
Because RE11 are more expensive and slower then RS3
