offset for 19" wheels
Old Jan 15, 2004 | 10:32 AM
BlackNissan350z's Avatar
BlackNissan350z
Default offset for 19" wheels
Ok I have done a search but have a hard time finding a definate answer....
I am lookin at gettin some 19" Axis Milano wheels, they are 19x8.5 up front with a 2.25" lip these run in 15,35,40,47mm offsets, the rears are 19x9.5 with a 3.5" lip and these run in 20,40,45mm offsets...so my question is which offset for front and rear are gonna fit best on a 2003 performance model.
Old Jan 15, 2004 | 11:58 AM
N74DV's Avatar
N74DV
on a 19x9.5 I'd go with the 20mm offset. 45 is WAY to high..... they'd be sitting pretty far inside.
Old Jan 15, 2004 | 12:11 PM
BlackNissan350z
what are the offsets on your rims? also doe the size of the lip have anythin to do with the offset
Old Jan 15, 2004 | 12:18 PM
N74DV's Avatar
N74DV
lip has nothing to do with it. offset in combination with wheel width will tell you all you need to know.
my offsets are about 25mm in rear (9.5" rim) and 12mm in front (8.5" rim)
Old Jan 15, 2004 | 12:26 PM
BlackNissan350z
well im thinkin about goin with the 15mm up front and 20mm rear...what do u think?
Old Jan 15, 2004 | 10:16 PM
vfr350's Avatar
vfr350
so i was looking at a set of 18" with 35 offset 8.5 wide for all four corners, are you thinkin they would sit to far in???
Old Jan 16, 2004 | 01:23 AM
N74DV's Avatar
N74DV
that'll work. the rear will be pretty close to the fender but it should just barely clear
Old Jan 16, 2004 | 01:24 AM
N74DV's Avatar
N74DV
35 on an 8.5 is not too bad but it is a little higher than it should be. You should look for a 25 or so for that.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
