Bent Wheel
Old Jan 15, 2013 | 01:22 AM
JDMStanced's Avatar
JDMStanced
Default Bent Wheel
I hit a big rock and the inner side of the rim got bent.
The tire guy balanced the wheel fine though. Would this cause premature tire wear and vibration?
http://s785.beta.photobucket.com/use...f6aa2.jpg.html
Old Jan 15, 2013 | 06:11 AM
red roadster's Avatar
red roadster
Did it cause the tire to have a untrue run out? If runout is still true and there is no air loss causing under inflation and it balanced then no problem. There are people who repair wheels if you want. Search alloy wheel repair on the net. Had some Boyd wheels repaired several years ago, that were on a 34 ford street rod, and couldn't believe how well it turned out.
Old Jan 15, 2013 | 06:54 AM
terrasmak's Avatar
why do you have bicycle tires on your car?
Old Jan 15, 2013 | 08:03 AM
mr. sparco's Avatar
mr. sparco
Stanced Z worried about tire wear?
Old Jan 15, 2013 | 08:08 AM
ZS14RR's Avatar
ZS14RR
Lol....
Old Jan 15, 2013 | 08:10 AM
Jcrisp's Avatar
Jcrisp
Had the same thing happen to mine and i got mine repaired, its worked fine so far since september..
Old Jan 15, 2013 | 09:03 AM
juicenigk's Avatar
juicenigk
Old Jan 15, 2013 | 09:46 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
It should be okay in terms of additional tire wear, but you get a bit more vibration here or there.
You should try to have it repaired.
Old Jan 15, 2013 | 01:07 PM
freddys 350z's Avatar
freddys 350z
op, i would be worried about loosing air. not so much the balancing. but...if you run proper size tires on those wheels the rock would of never bent the wheel, just saying.
Old Jan 15, 2013 | 08:00 PM
TuckerE36's Avatar
TuckerE36
OP did your front bumper get furked up from the rock too?????
Old Jan 15, 2013 | 08:13 PM
cman350z's Avatar
cman350z
I hooked a concret barrier at the local mall parking lot bent the front right rim . I had it repaired at a metel shop , it would not balance properly ...I ended up going online and ordering a replacement stock rim .
Old Jan 15, 2013 | 09:16 PM
JDMStanced's Avatar
JDMStanced
i would need to wait and see if the air holds. It should though.
i got rid of BICYCLE TIRES and installed 235.
Old Jan 15, 2013 | 10:52 PM
Waiz's Avatar
Waiz
Depending on how severely the wheel was bent this will cause a fair amount of vibration
Most shops can repair the bend for around $100, just get it done and then get an appropriately sized tire after or this will keep happening
Old Jan 15, 2013 | 10:55 PM
805350z's Avatar
805350z
It won't cause much, i've had worse without knowing it. Nice bicycle tire.
Old Jan 15, 2013 | 11:07 PM
JDMStanced's Avatar
JDMStanced
thanks guys for replies.
i don't regret getting rid of bicycle tires haha. 215 -> 235 is a BIG difference in traction ahah. But i still like the bicycle tires look though haha
