18X10 Mid Offset - Tire Size Help
Old Jun 30, 2013 | 11:14 PM
scottvernard21's Avatar
scottvernard21
Default 18X10 Mid Offset - Tire Size Help
Hello Everyone, I have a 2003 350Z, i installed after marked wheels a couple of years back, 18X10 MID offsed, all four cornes. I am currently running a 245/45/18 tires. They had to install spaces on the front to stop the front wheels from rubing on the struts(desperate and unexperienace on my part). I do not like the way the tires look on the wheels, they look stretch on the rim. Can anyone recomend me the right size of tire need it with out having to do any changes to the fenders?I was thinking 255/40/18 and should i also space the back wheels to keep the car balance? or should I just replace the rims and get rid of the headache? please help...
Old Jun 30, 2013 | 11:18 PM
KingBaby's Avatar
KingBaby
Hardest Setting
First we need to know what is "MID offset" is then proper advice can be had...
Old Jul 1, 2013 | 12:18 AM
scottvernard21
MID offset is what the wheels avertise....i dont have the exact mesurement but I though Mid is between 16-34 mm. but they barely rub inside on the struts thats why the put the spacers...
Old Jul 1, 2013 | 02:26 AM
terrasmak's Avatar
What brand wheels , that may be a great start. You can typically look up offset if you know the brand.
Old Jul 1, 2013 | 09:23 PM
DarkCreep's Avatar
DarkCreep
Pictures and brand would help.
Old Jul 1, 2013 | 10:11 PM
taryon's Avatar
taryon
I ran 265/35 and 265/40, and also 265/40 and 285/40 on my 18x10 +26 all around. Since the front is rubbing on the struts, I would assume the offset to be higher, maybe around +30. Most people would go with 265/35 and 285/35 as it's a more popular setup, the 40 series can be seen as bulgy and big
Old Jul 2, 2013 | 04:19 PM
Waiz's Avatar
Waiz
245-45-18 is too small OP for an 18x10.5
Old Jul 2, 2013 | 04:44 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
I have 18x10 +24 wheels matched with 275/40/18 tires.
