PSA: When asking "will this rub"....
I just bought RPF1s at 18x10.5+18,lugs, and hub centric rings. I only have rear camber arms installed at the moment, everything else is stock, but I have a couple questions. I've looked into what tire size is good for these wheels and I've read 265/35 square is a great setup to run for street and a bit of track. Does that sound okay? I plan on lowering my car in the future with springs about an inch so I guess I'll have to roll my front fenders, maybe not the rear.
350Z/370Z Tech Moderator
265/35-18 is way too short. By nearly an inch. Fine for track/AX but not so good for the street. Speedo error, clearance issues, VDC error all possible. Not huge issues that can't be worked around but still too short. I bought a set of wheels that had these mounted (from a Subie or something). Gave 'em away.... unusable on my Z.
225 45% 18 25.97 Stock Reference Size
245 45% 18 26.68 Stock Reference Size
245 40% 18 25.72 Front-Alternate
255 35% 18 25.03
255 40% 18 26.03 Front-Alternate
255 45% 18 27.04
265 35% 18 25.30
265 40% 18 26.35
275 35% 18 25.58
275 40% 18 26.66 Rear-Alternate
285 30% 18 24.73
285 35% 18 25.85
285 40% 18 26.98 Rear-Alternate
I won't give a recommendation on square... I don't do, don't like, don't need a square setup. Way too much understeer for my taste. (FOR MY USE, which isn't on track.) Others will be able to make recs.
+18?? That a new size? Enkei spec sheet doesn't list a +18... just wondering.
255 35% 18 25.03
255 45% 18 27.04
265 35% 18 25.30
265 40% 18 26.35
275 35% 18 25.58
285 30% 18 24.73
285 35% 18 25.85
255 35% 18 25.03
255 45% 18 27.04
265 35% 18 25.30
265 40% 18 26.35
275 35% 18 25.58
285 30% 18 24.73
285 35% 18 25.85
You can run a 255 on 10.5 wheel. You're still above the 90% wheel width:tire width ratio so the tire will have a modest amount of sidewall angularity to the bead (I won't say stretch because if you're over 90%, it's not really stretching the tire.)
S'far as rubbing, almost anything 275 and above will rub on the rear with >9.5 wide with +15 offsets unless you roll the fender lips. (Ask me how I know this....) That's on a lowered car BTW, not sure about stock height. Might still be close and may take a bigger bump to rub.
Pokin' with a 10.5 +15 up-front and a 255 on that wheel width isn't something I'd put on my Z (fitment, performance, aesthetics...just another opinion FWIW).
Would consider 265/40 and 285/40's if in your shoes, roll when/where you need to pre/post lower and consider alignment specs/parts every step if the way.
I'm with Mic, square for a 99% street ride...not interested.
Looking to get a custom set of Forgestar F14s for auto-x Street class (stock springs and OEM front camber) on my 2007 Grand Touring 350z, can anyone offer some insight on the following:
Front - 275/35/18 18x9 +23
Rear - 275/40/18 18x10 +23
My initial research leads me to believe that this setup shouldn't be an issue.
TIA
TIA
TIA
TIA
I would love to but because of SCCA rules I am unable to do so. You are only allowed to change offset by +/- 7 mm, rim diameter by +/- 1" while width must remain the same. I am therefore stuck with 9" fronts and 10" rears.
Tires that will NOT rub 245/40-18F & 275/40-18R.
But bottom line, +32 works but is a little larger than OE, barely noticeable, if at all from stock. Just depends on the look and track you're seeking.
