PSA: When asking "will this rub"....
Old Mar 25, 2022 | 03:01 AM
  #521
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by travlee
255/40/18 front
275/40/18 rear
Bzzzzt. He has 19s.
245 OR 255/35-19F
275 OR 285/35-19R
10.5 +22 offset rear will be close lowered, may need roll.
Old Mar 25, 2022 | 03:06 AM
  #522
travlee's Avatar
travlee
Master
psssh, whats one inch? i honestly missed that
Old Mar 25, 2022 | 03:08 AM
  #523
MicVelo's Avatar
I won’t go there.
I won’t go there.
Please stop me from going there. 🤡
Old Mar 25, 2022 | 03:52 AM
  #524
travlee's Avatar
travlee
Master
its a short subject
Old Mar 25, 2022 | 06:00 AM
  #525
Asher king's Avatar
Asher king
Originally Posted by MicVelo
Bzzzzt. He has 19s.
245 OR 255/35-19F
275 OR 285/35-19R
ok so even with a square setup i do different size tires from front to back?
Old Mar 25, 2022 | 10:22 AM
  #526
MicVelo's Avatar
Your choice. But if your car is equipped with VDC, then suggest you stay with staggered front to rear so as to reduce possibility of VDC error (triggering it) due to erroneous wheel speed misreads. Square set up is good for track use but if you have VDC, don't recommend for street/highway. Hotly debated topic here but staggered is how the car came from the factory so unless you're racing and need a bigger reduction in oversteer, I'd stick with staggered.
My $.02.
Old Mar 25, 2022 | 10:23 AM
  #527
travlee's Avatar
travlee
Master
17 and 18 inch also came from the factory....
Old Mar 25, 2022 | 10:34 AM
  #528
MicVelo's Avatar
Yep and both were staggered tire setups even with squared wheels (Touring "Wagon Wheels").
Old Mar 25, 2022 | 11:18 AM
  #529
Asher king's Avatar
Asher king
My $.02.
ok thanks for the help so from my understanding ill go with a staggered setup basically only with the tires and the wheels being square i dont have those settings so i should be good
Old Apr 24, 2022 | 06:44 PM
  #530
Smitttyy's Avatar
Smitttyy
Default Will this rub?
18x10.5 +22 front and rear stock suspension. 265/40 front 285/40 rear nobody within 3 hours of me rolls fenders so trying to avoid that but also get as much of my wheel gap filled
Old Apr 24, 2022 | 06:55 PM
  #531
MicVelo's Avatar
Unless you go with "show camber", there is likely interference. 265/40 will "most likely" rub but maybe not on the fender lips, more likely on the fender liner bolt and/or suspension uprights. Talking nearly 3/4" larger diameter some 40mm more poke.
Old Apr 25, 2022 | 04:50 AM
  #532
Smitttyy's Avatar
Smitttyy
Default What size do you think will fit ? I was thinking 255/40 if not
do you think a 255/40 would fit better ? I just don’t want the tires to stretched on the wheels if not possibly a 245/40
Old Apr 25, 2022 | 05:04 AM
  #533
travlee's Avatar
travlee
Master
i ran 255/40 and 275/40...
Old Apr 25, 2022 | 08:17 AM
  #534
Smitttyy's Avatar
Smitttyy
did you have any issues with any rubbing ?
Old Apr 25, 2022 | 08:26 AM
  #535
travlee's Avatar
travlee
Master
top center fender liner screw would rub, i just took it out
Old Apr 25, 2022 | 08:28 AM
  #536
travlee's Avatar
travlee
Master
i was 18x9.5+15 in rear, and 18x9.5+22 front
Old Apr 25, 2022 | 10:14 AM
  #537
Smitttyy's Avatar
Smitttyy
ah man do you think I will have issues with those tires sizes on 18x10.5 +22 front and rear
Old Apr 25, 2022 | 10:40 AM
  #538
travlee's Avatar
travlee
Master
i think you will have problems up front, unless you have a ton of camber
Old Apr 25, 2022 | 11:16 AM
  #539
Smitttyy's Avatar
Smitttyy
Hm what size do you think I could get away with without rubbing up front, also while keeping my stagger in the rear from being over a 30mm difference like would a 255/35 be any better ? I apologize for all the questions just trying to make sure I get the sizing right before I spend over a thousand on rubber I have 225/40s all around right now and I’m worried I’m gonna die soon with all that stretch
Old Apr 26, 2022 | 09:06 PM
  #540
terrasmak's Avatar
255/40 and 275/40 will be a pretty safe bet
