Need helping picking right size tires...
Old Oct 3, 2013 | 12:32 AM
CJs_Z33's Avatar
CJs_Z33
Default Need help picking right size tires...
Like the title says, I need help picking the right size tires for my set up. Ill be running a set of MB Battles 18x9.5 +15 rims, 25mm spacers in the rear, 20mm spacers in the front. Car will be left at stock ride height. Looking for the widest tire I can run without having to pull or roll my fenders. Thanks!
Old Oct 3, 2013 | 06:18 AM
Bmurray350z's Avatar
Bmurray350z
I'd probably do 255/40 F and 275/40 R.
You could also do 265/35 square,
265/35 F & 265/40 R,
275/35 F & 275/40 R
Also, you probably wont need that large of spacers.. probably none for the front. Maybe a 10-15mm for the rear. Just wait and see.
Old Oct 3, 2013 | 06:55 AM
terrasmak's Avatar
If you want wide, don't install your spacers.
Old Oct 3, 2013 | 07:13 AM
travlee's Avatar
travlee
Master
if you put that size space on the rear you will have the wheel and tire sticking past the fender, acid jake on here has same wheel and he sits flush with the fender
Old Oct 3, 2013 | 07:28 AM
ZS14RR's Avatar
ZS14RR
First of all why battles?? They are fugly
Old Oct 3, 2013 | 07:32 AM
travlee's Avatar
travlee
Master
^cheap and decent looking.... but not everyones cup of tea
Old Oct 3, 2013 | 07:48 AM
ZS14RR's Avatar
ZS14RR
Enkeis? Vardogs?
Old Oct 3, 2013 | 07:56 AM
travlee's Avatar
travlee
Master
Originally Posted by ZS14RR
Enkeis? Vardogs?
enkeis approx $350 each for 9.5 +15
battles less than $200 each for same size
Old Oct 3, 2013 | 08:29 AM
terrasmak's Avatar
You can get Battles for $150 each, Rota for just over $200 each , Enkei 9.5's for $260 each and 10.5's for $300 each if you shop around.
I would save a few extra penny's and get Rota at minimum
Old Jan 1, 2014 | 11:30 PM
CJs_Z33's Avatar
CJs_Z33
Just an update, I installed the wheels the other day and I see what you guys mean about the spacers. I like how the front sits flush with the fender. I'm thinking of picking up a set of 15mm spacers for the rear to match the fitment up front. I ended up sticking to the factory spec tires 225/45 F and 245/45 R. Ill be running 255/40 F and 275/40 R once my tires go bold. I might have to roll the rear fenders when I make the switch to 275's. Thanks for the input guys.
Old Jan 1, 2014 | 11:33 PM
CJs_Z33's Avatar
CJs_Z33
I purchased the wheels from discount tire direct for $666 shipped. They had a $50 instant online discount.
Old Jan 2, 2014 | 12:18 AM
terrasmak's Avatar
The 275/40 rear may slightly rub in the rear at +15, once rolled you can install a 10 to 15mm spacer no problem.
Old Jan 2, 2014 | 12:15 PM
CJs_Z33's Avatar
CJs_Z33
You're from vegas right? Know any local shops that roll fenders for a good price?
Old Jan 2, 2014 | 02:22 PM
travlee's Avatar
travlee
Master
with a 275 tire and the battles being +15 you will rub*. i just went through this... rolled em and no probs now
*note i am lowered 1 inch on eibach pro kit
Old Jan 2, 2014 | 06:13 PM
terrasmak's Avatar
I would hit up Buckey to do it. I don't have his shop info on me, check for his info on Vegas Drift.
Old Jan 2, 2014 | 07:36 PM
CJs_Z33's Avatar
CJs_Z33
thanks ill get spacers after getting them rolled. thanks man!
yeah i think i know who he is. he has a read fc right?
Old Jan 3, 2014 | 12:21 AM
terrasmak's Avatar
Red FC, tell him I sent you
Old Jan 3, 2014 | 12:50 AM
CJs_Z33's Avatar
CJs_Z33
RED haha ill pm him on vegasdrift and see how much he will charge. im also on 350zen and on vegasevos so ill see who they got too.
DarkCreep
Oct 17, 2015 11:50 PM
AchilleZ
Oct 11, 2015 09:45 AM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
