Help with Offset Please
Old Nov 17, 2013 | 10:54 AM
NewZdriver33's Avatar
NewZdriver33
Default Help with Offset Please
I'm getting a set of Work Gnosis GS2's, 19x9.5/10.5 and I need to know what offset I should go with. 05 350z base. I'm going to be running BC coilovers.
Old Nov 17, 2013 | 11:22 AM
Spike100's Avatar
Spike100
^^ +22mm offset is safe (no rubbing) with your wheel sizes. That is not flush and some members here want more offset.
Once you get to a+19mm with a 10.5” wheel and a 285mm tire, you may rub. If you do rub, the fix is rolling the fender.
--Spike
Old Nov 17, 2013 | 11:33 AM
NewZdriver33
What would give me a flush look? If possible with those wheel sizes?
Old Nov 17, 2013 | 11:49 AM
SR71's Avatar
SR71
Lead Super Moderator
Read and learn
https://my350z.com/forum/wheels-and-...es-thread.html
https://my350z.com/forum/wheels-and-...s-welcome.html
Old Nov 17, 2013 | 11:52 AM
Spike100's Avatar
Spike100
Depending upon the tire brand and the tire size (the same size might not be identical in a different brand), an offset of +18mm-19mm will be flush, but may rub; and thus require rolling your fenders.
I repeat… +22mm offset is the safe value with your wheel sizes.
--Spike
seagrasser
Oct 11, 2015 03:27 PM
