Different Brands of Tires
Old Jun 9, 2014 | 02:15 PM
Will_Cog's Avatar
Will_Cog
Default Different Brands of Tires
Hi
So I have to buy only one new rear tire. I have puncture near the sidewall and the rear tires only have about 10K kms on them.
Question is should I buy another Bridgestone Potenza (Stock) tire or 2 Hankook Evo K110. The tire shop near me will charge me the same price for 1 new Bridgestone or 2 new Hankooks.
Is it bad to have Bridestones in the front and Hankooks in the back?
Any replies appreciated.
Old Jun 9, 2014 | 02:49 PM
need 4 speed's Avatar
need 4 speed
Vendor - Former Vendor
At the end of the day if your not tracking your car, and are not trying to squeeze every single ounce of performance from your 350z, then you will be just fine with different brand tires around.
Old Jun 9, 2014 | 02:55 PM
ksuberk54's Avatar
ksuberk54
Not at all. Many people have different brands. It's fine since our cars are staggered anyways.
Old Jun 10, 2014 | 05:02 AM
terrasmak's Avatar
I have no problem mixing tires, but they will always be matched from side to side.
Old Jun 10, 2014 | 05:07 AM
iideadeyeii's Avatar
iideadeyeii
Quantity over quality
Old Jun 10, 2014 | 05:19 AM
Syner's Avatar
Syner
I have different tires between front and back. But like terras said, they are match side-to-side.
Old Jun 10, 2014 | 07:29 AM
scotts300's Avatar
scotts300
What size?
Old Jun 10, 2014 | 01:55 PM
Will_Cog's Avatar
Will_Cog
If I get stock then the Bridgestones would be 265/35/19. However, with the Hankook they would be 275/35/19.
Thanks for the feedback everyone!
Old Jun 11, 2014 | 03:14 AM
bjr's Avatar
bjr
Default for what it's worth
Be warned that every mixed set of tires I have tried were twitchy in the rain. The only way I can explain it is that different corners of the car can pull a little different cornering. It felt similar to putting on directional tires spinning the wrong way. The car kind of fights itself around corners and through standing water. And mine were all with one style in front and another in the rear. One single different tire may be a little less noticeable?
If the identical tire is still available I recommend getting it. You already have started a cycle of uneven tire replacement intervals. At some point you will go to get a full rear set or all four and that last one will be a shame to throw away with a lot more tread on it but you cannot plan around life's little mishaps.
Dry pavement you will be fine but be careful when it gets wet! Depends on tread design but I IMIAGINE it could be anywhere between something noticeable and something a little dangerous. Be careful...
Old Jun 11, 2014 | 04:09 AM
SQuaLZ's Avatar
SQuaLZ
I would get the brand that you plan on eventually changing the fronts with.
Soon after I got my Z, I got a nail in the sidewall of one of my rear tires. Ended up getting talked into buying 2 Potenzas for the rear to match the front. A few months later I needed 2 new fronts, and since I hated the Potenzas I opted to get 4 new BFGoodrich tires. I basically wasted a nice chunk of change getting the 2 Potenzas, and I have actually been trying to sell them here on the forum for a while now with no interest.
