Performance Nissan - Upper Control Arms!
Old Feb 8, 2004 | 02:55 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Default Performance Nissan - Upper Control Arms!
They are finally available and WOW! they are everything and more then we expected!
Performance Nissan Racing - Upper Control Arms
For those of you who want to adjust your front camber and easly switch it out for daily driving or track use then here you go.
Have your Daily Driving set up. When you get to the track. Jack up your car like you are changing a front tire, take off 2 bolts and remove the shims, replace with the best shim combination for your desired camber setting, tighten bolts, and BAM! Still in alignment spec with an aggressive camber for tackling those corners! when you want to leave the track, put in the shims for street use and drive home with a nice low tirewearing camber angle...
PM me if you are interested in purchasing these to get my special price to you
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
