255/40r18 & 295/40R18 ?
Old 03-04-2015, 07:37 PM
lp_turbo
lp_turbo's Avatar
Default 255/40r18 & 295/40R18 ?
Hello, I really need more traction with over 575hp and saw the Falken Azenis I tried at earlier and much loved..very good quality/price
The problem is a big ratio for vdc if I take the 255/40R18 and 295/40R18 for maximum width fit on my Enkei RPF1 9.5 & 10.5 with 15mm offset..i know it was in my fender but for the VDC, has anyone tried?
This is for track day and street use..
You have something else to suggest to me?
My other choice is Kumho XS 245/35R18 & 275/35R18 but the road here (Quebec) aren't like yours and would like more sidewall for comfort
Old 03-04-2015, 07:42 PM
terrasmak's Avatar
Received 2,291 Likes on 1,651 Posts
285/35-18 RS3 would hook well, and run a 265/35-18 front
Old 03-05-2015, 04:14 PM
lp_turbo
lp_turbo's Avatar
Ok thanks Terrasmak, you think Nitto NT01 275/35 frt and 305/35 rear can fit without crazy camber ?
I do a lot of highway for work..
Old 03-05-2015, 10:04 PM
terrasmak's Avatar
The rear will need a lot of a roll and the upper ends of OEM spec camber. The 285/35 can run less camber giving you a better contact patch. Also the RS3 will last much longer on the road and takes wet roads much better
Old 03-06-2015, 04:16 AM
lp_turbo
lp_turbo's Avatar
Ok, RS3
Thanks again!
dhays
01-12-2009 08:56 PM
A06ZRT
350Z Roadster
06-15-2007 08:59 PM
DVanditmars
12-19-2005 05:03 PM
Driven
12-11-2002 10:03 AM
Quick Reply: 255/40r18 & 295/40R18 ?
