tire size help
Old Mar 14, 2015 | 07:28 AM
darkgt's Avatar
darkgt
Default tire size help
so the 245/45/18s on the rear are starting to loose a bit of traction as I progress in the mods wondering what will be best for my set up and what will fit before I buy it. Intended use daily driving with spirited driving on the weekend wanna keep the traction in straight and curves in case I want to hit the drag strip or the auto cross.
on track v 1 wheels 18x8f and 18x8.5r I want to move the 245/45/18 up front and put either a set of 255/45/18 or 265/45/18 on the rear I have a base so no electronic issues to deal with, and with nismo springs for my suspension height. Or maybe I should go with a different size all together? Open to knowledge of those who have been here before me.
Old Mar 14, 2015 | 08:23 AM
terrasmak's Avatar
Since you are very limited by wheel width 245/40-18 front and 255/40-18 rear
Old Mar 14, 2015 | 08:38 AM
darkgt's Avatar
darkgt
do you think the 45 series would work as well trying to keep the ride kind of smooth as well?
Old Mar 14, 2015 | 08:51 AM
terrasmak's Avatar
The 245/40 front is very close to the same as the stock 225/45 so ther is hardly a difference in harshness the rear tire I suggest is slightly shorter and will have hardly any noticeable difference in ride quality.
The type of tire you buy will dictate harshness, many tires of the same size will ride very different
Old Mar 14, 2015 | 08:53 AM
darkgt's Avatar
darkgt
so that means I could also stick with the 225/45 up front as well and just switch the rear? or would that throw handling off too much?
thanks for the help sorry for all the questions, use to running rwd 17s/16s much larger sizes or having a fwd car
Old Mar 14, 2015 | 01:55 PM
dykel3fiddyz's Avatar
dykel3fiddyz
I have Nitto Invo's 255/40/19 in the front and 305/40/19 in the back. But I dont have liners.
Old Mar 14, 2015 | 02:11 PM
darkgt's Avatar
darkgt
I actually found a set of new invos on craigslist 255/45/18 im gonna go pick up tomorrow for the rear for a good price
Old Mar 14, 2015 | 04:07 PM
terrasmak's Avatar
They will work, but .... I stick to my previous suggestion if your trying to improve the handling and traction.
Old Mar 15, 2015 | 12:00 AM
darkgt's Avatar
darkgt
I have nexens on the rear right now I'm sure anything would be an improvement at this point
