18X9.5 AND 18X10.5 +22, requirements
Old May 16, 2017 | 10:26 AM
club350's Avatar
club350
Default 18X9.5 AND 18X10.5 +22, requirements
Hey there,
I'm just looking through these forums trying to see what's required with this setup...
18x9.5 +22 275 tire (front)
18x10.5 +22 295 tire (back)
I'm sure I'll have to fender roll as it says BUT is that all? I want to be able to do this setup without going wide bodykit because I like the bodykit I have. I don't mind if wheels are sticking out under fenders.
Old May 16, 2017 | 10:46 AM
jhc's Avatar
jhc
General & Tech Moderator
That's my setup, but 265/35/18 fr and 295/35/18 rr. Mine are +12, backs are rolled. Auto Xers run 275 square, pretty sure you'll be fine.
Old May 16, 2017 | 11:16 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by club350
Hey there,
Your desired tire sizing is pretty aggressive at +22 offset but it'll "probably" work with a little prep. (Although I have had 295/40 on the rear without any issues - but on a less aggressive offset pair of rear wheels.)
Generally speaking, on a lowered car, the "typical" 18" set-up is 255/40 & 285/40 (or 245/275).
In addition to rolling rear lip, you'll likely need to cut down the front fender liner bolt.
This is the 255/35 & 285/35 on same size/offset wheels (19s, but all other measurements - heights, widths, offset, the same...)
Lowered 19mm, rear fenders full rolled, front fender bolt UNcut, NO spacers)
zwei_the_c
Mar 16, 2026 03:13 PM
OAKOSAutomotive
Jul 18, 2018 01:09 PM
OAKOSAutomotive
Vendor Group Buys
118
zwei_the_c
Apr 27, 2017 04:30 AM
Persades
Apr 26, 2017 06:59 AM
