Wheel offset for 05 Nissan 350z?
What's the recommended off set for my car. Right now I have XiX rims and they're almost sticking out past the fender. The wheel size is 245z35zr20. I'm just trying to buy a spare.
Is it +20 ?
Is it +20 ?
350Z/370Z Tech Moderator
GENERALLY speaking, offsets can be as low as +10 on a "narrow" wheel, say 8", or need to be upwards of +20-25mm for a very wide wheel - say 10.5"+ for proper clearance without fender interference.
Guessing that you're down in the 8.5-9.5" range with that size tire and assuming front application?
So how wide are these 20s?
Depends on the wheel width.
There's NO WAY an 8.5" +30 wheel will stick out. NO WAY. Even a +20 shouldn't. You sure there aren't spacers on the car??
FWIW, an 8.5" wide +30 offset wheel will sit in the wheel well EXACTLY like what the car had on it OEM, slightly tucked into the well by about 15-20mm from the inside-top of the arch.
As Trav pointed out, look at the crashed wheel's backplane and verify the offset PLUS, check to see if the previous owner (if you haven't take the wheel off before) added spacers because those numbers just don't add up.
If anything, it'd be easier to get +35 and add spacers to match the others' offsets. BUT I'M NOT RECOMMENDING THAT. Just explaining that your thinking on that was flawed. Not in bad way, again, just explaining.
Instead, do as travlee says below:
https://my350z.com/forum/wheels-and-...t-novices.html
Explains how to determine your offset with a ruler and straightedge.
