18" Square track wheel size
Old Sep 28, 2017 | 11:36 AM
B-radDetail's Avatar
B-radDetail
Default 18" Square track wheel size
I am looking for recommendations on 18" wheels that I can run a 275/35/18 square set up without fender rolling or spacers. Must be able to clear the brembo brakes.
I have searched and search, looked at many different options, but no definitive answer.
Thanks,
Brad
Old Sep 28, 2017 | 02:03 PM
carbuffguy's Avatar
carbuffguy
Thanks,
Brad
Why are you looking at a square setup? Racing?
Mic is the tire/wheel man here...I'm sure you'll be hearing from him
Old Sep 28, 2017 | 02:47 PM
terrasmak's Avatar
RPF1 in 18x10.5 in the common and works great, but the rear fenders will need a slight roll.
You can drop to the 18x9.5 +15 and be fine without rolling
Personally I would buy a wheel with a width less then 10
Old Sep 28, 2017 | 05:18 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Concur. ^^^ I'd go with RPF1 (or other Enkei "Race" wheel for a track-oriented car per the title.)
But, just my experience, I had to roll rears to take the occasional bump out of the back end with the 9.5 +15s but with 275/40 (nearly exact same rolling diameter as OE fit tires), not the 35s, which may work per terrasmak's recommend.
Old Sep 28, 2017 | 05:52 PM
carbuffguy's Avatar
carbuffguy
Right, caught that post post
Old Sep 28, 2017 | 07:56 PM
djnekkon's Avatar
djnekkon
just as an example. My enkei RS05RR
front: 10" ET +12 - tire 265/35/18. camber -2 = no fender work (285 0r 275 did not work
for me) cleared brembo by 2mm.
Rear: 10.5" ET 15 - tire 295/35/18 camber -2 - no fender work. cleared brembo
so I am pretty sure you can do 10" ET +15 tires 265/35/18 all around without fender work and some camber.
I am only dropped .75
Extreme Dimensions
Body Exterior
Oct 20, 2016 12:59 PM
ssmokeyy
Oct 1, 2016 08:39 PM
juang20
Interior
Jan 11, 2016 02:24 PM
dc350z
May 28, 2002 12:09 PM
