Sorry: 20x9 225/35zr20 2 x 20x10 275/30zr20?
Old Apr 21, 2018 | 10:05 AM
coop3422's Avatar
coop3422
Question Sorry: 20x9 225/35zr20 2 x 20x10 275/30zr20?
Hey everyone,
I did some searching on Google, didn't find a definitive answer so thought I'd ask. Not looking for 20" wheels, but these came up locally and I'm intrigued. Axis wheels with Federal 595 rubber. Not perfect, but good from what I've read. Specs are:
20x9 225/35zr20 roughly +30
20x10 275/30zr20 roughly +20
Waiting for exact offsets.
I didn't think they'd work with a taller tire up front, but after looking online I saw a thread where people said it would work, I assume because if the width. Anyway, I have an 07 Grand touring on stock wheels and ok tires. Just got the car and the wheels have a decent amount of rash, and the front are all seasons and rears are good summer tires. So I've been looking at just 18 wheels and swapping rubber, as well as 19 wheel and tire combos. Wasn't going to do 20's, but these are a good price. They'd also show off my Brembos nicely lol.
Thanks
Old Apr 21, 2018 | 10:14 AM
bealljk's Avatar
bealljk
I wouldnt go with 20" wheels no matter the price or the tires. I did this and it really slowed the car down - I didnt think I'd notice but the additional mass of the wheel was taxing on the car. It also brought down the economy/mpgs of the car too.
I'm sure 'some' 20" wheels look ok on the car but very few ... after a few years of having my 20" I thought they started looking bad.
just my 2cents...
Old Apr 21, 2018 | 09:13 PM
terrasmak's Avatar
Just trying to figure out the math on the taller tire up front. Maybe it’s that new common core stuff or something.
Using regular old trusty math, it appears the front tire is shorter than the rear by about 3/4 of an inch.
Other than being 20’s it’s a setup. You may want spacers, 15 to 20mm to bring the wheels out where needed
Old Apr 22, 2018 | 07:01 AM
No_name's Avatar
No_name
Originally Posted by bealljk
"...wouldn't go with 20" wheels no matter the price or the tires."
+1. Don't like the idea of a 225 on a 9 x 20" +30 wheel up-front period. Paired with that rear? You'll want to read-up on understeer.
Old Apr 22, 2018 | 07:05 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by coop3422
Hey everyone,
Thanks
225 45% 18 25.97 Stock Reference Size
245 45% 18 26.68 Stock Reference Size
225 35% 20 26.20 +0.23"
275 30% 20 26.50 -0.18"
Heightwise, they'll work (not optimal but workable) but I'd be more concerned about the huge tread width stagger. That 50mm delta F-R sounds a lot "understeery" to me. (Not to mention the weight and offset mentioned by others above.)
Personally, I know how tempting a good price on "cool wheels" can be but I'd still weight for the RIGHT set to come along. Doing it wrong means you'll be out shopping for wheels again in a couple months.
Old Apr 22, 2018 | 07:47 AM
No_name's Avatar
No_name
Originally Posted by MicVelo
...huge tread width stagger. That 50mm delta F-R sounds a lot "understeery" to me.
Agreed Mic. While "the math" looks acceptable on paper vs OEM spec one can almost guarantee that stretched 225 is is not going to perform well paired with a "more sticky" spec out-back. Add into the mix tire profiles F/R with those sizes on 20"'s, exacerbated off-set F/R*, weight as mentioned and inevitable wear-up-front (which I believe would manifest early-on)...that's a no-go setup for someone seeking performance.
*Spacer on that +30 but no free-lunch.
Old Apr 22, 2018 | 08:56 AM
bealljk's Avatar
bealljk
weight
hhaaaaaaaa!!
For reference - my 20x9 fronts weighed 57lbs, my 20x10.5 rears weighed 65lbs ...
I swapped over to a set of enkei RPF1s 18x10.5" are 44lbs ...
so I dropped 42lbs of rotational mass in the rear and 26lbs in the front...the difference was night & day...
Old Apr 22, 2018 | 09:17 AM
coop3422's Avatar
coop3422
Thanks Mic, this was a helpful reply. On paper I thought they might work ,but not ideal. I'll wait for something else to come along.
I stopped past my storage yesterday to check what the tires were. Fronts are Falken Ziex ze912 in 225/45/18, rears are Nitto Motivo in 245/45/18. Both tires seen seehave decent reviews, even if being a high performance all season. I'll keep looking for other deals.
PostRelease
Aug 20, 2009 05:00 AM
PostRelease
