03 350z doesnt accelerate
Old Jul 17, 2018 | 01:37 PM
JeanPaul350z's Avatar
JeanPaul350z
Default 03 350z doesnt accelerate
i have a 350z 03 .. Slip ,VDC,engine light on and when i press on the gas it only goes up to 1500rpm sometimes when i first turn the car on it goes up to 3k,3500 rpm and then when i press on the gas again it only goes up to 1500 again and it wont pass it.. i can put the car in 1st and reverse and it will move but when i press on the gas in wont accelerate..ecu is good , i changed the throttle body and the pedal sensor ...i dont know what else it can be anyone know please lmk i had these issue for 3 weeks already i dont know what else it could be
Old Jul 17, 2018 | 01:58 PM
mr. sparco's Avatar
mr. sparco
Any codes? Did you do the throttle relearn procedure?
Old Jul 17, 2018 | 03:14 PM
JeanPaul350z
i dont have the codes on me right now.. no how do i do the throtle relearn produre? thanks for answering
Old Jul 17, 2018 | 04:29 PM
terrasmak's Avatar
lets worry about the codes first. The relearn just helps it idle smooth and not stall on start
Old Jul 19, 2018 | 12:24 PM
Zkiwi's Avatar
Zkiwi
Someone thinks you might have changed your wheels / tyres fooling the speed sensors with wrong rotation rates differential. Then it thinks you are spinning the rear and cuts the power.
Old Jul 22, 2018 | 12:43 PM
JeanPaul350z
The codes are p2122 and p2138
Old Jul 22, 2018 | 01:44 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Accelerator pedal sensor.
Old Jul 22, 2018 | 03:26 PM
JeanPaul350z
I changed the throttle body and pedal sensor and still have the issue that my car won't rev up more then 1500rpm
Old Jul 22, 2018 | 04:39 PM
JeanPaul350z
Old Jul 22, 2018 | 08:19 PM
MicVelo's Avatar
Did you change the throttle position sensor or the pedal sensor?
Old Jul 23, 2018 | 04:19 AM
travlee's Avatar
travlee
Master
Take it to nissan
/thread
also, why is this in the wheels and tires section
Cameron Seibert
Jul 26, 2018 08:50 AM
Jmiller21
Jul 18, 2018 04:03 PM
bj-99
Jun 25, 2018 11:48 AM
DonnieDank
May 20, 2018 02:21 PM
MissFairlady_Z
May 11, 2018 08:30 AM
