Recommended tire size for 17x9.5 +22 and 17x10.5 +22
Hey guys, any tire recommendations for 17x9.5 +22 (front) and for 17x10.5 +22(Rear)? I am in stock height with stock suspension. Not trynna rub nor roll my fenders.
You could mount 245/45-17" Front and 265/45-17" Rear tires.
That is only about a 0.5% diameter difference from stock, and a nice setup on your aftermarket wheels.
With stock height, and +22 offset, you could easily go with a wider tire for both ends, without rubbing.. A 275mm tire may be slightly stretched on a 10.5 wheel, depending on brand.
Also, I would reccomend keeping a similar difference in width to the stock setup. I.e. 225/245 to 255-275, or similar.
