Need info on Pirelli P-Zero Rosso
Old Feb 22, 2004 | 07:16 PM
Zay's Avatar
Zay
Default Need info on Pirelli P-Zero Rosso
Hey Guys - I am going to soon replace my OEM tires and was wondering if any of you have any info and/or experience with the Pirelli P-Zero Rosso Direzionale? I know they put these tires on Boxsters as OEM. What's the scoop on this tire? I am also considering the Bridgestone S-03 Pole Positions and Toyo Proxes T1-S.
Old Feb 23, 2004 | 05:51 AM
lungta's Avatar
lungta
I had them on my Boxster S, they lasted 15k and are better than the RE040 in dry and wet and cold weather. But i havent tried any other tires so they might be some better ones
Old Feb 23, 2004 | 07:17 PM
Zay's Avatar
Zay
Thanks for the input lungta.
Anybody else have any input on these tires? Let me also pose another question... which tire do you feel is the best bang for the buck. Things to consider are performance (wet and dry), comfort/feel, road noise and tread life. Feel free to add to anything I left out... all comments are welcomed.
Old Feb 23, 2004 | 10:00 PM
350Zteve's Avatar
350Zteve
I have them. I was surprised how light they are. I'm very happy with them and would buy them again. Grip is good with them.
Old Feb 24, 2004 | 06:39 AM
Dolfan13's Avatar
Dolfan13
Checkout the link not as good as the goodyear or so2
Pirelli
http://www.tirerack.com/tires/tires....so+Direzionale
GoodYear:
http://www.tirerack.com/tires/tires....Eagle+F1+GS-D3
Bridgestone Potenza S02:
http://www.tirerack.com/tires/tires....l=Potenza+S-02
Check the tire wear and grip section should answer most of your questions.
Old Feb 24, 2004 | 10:53 AM
ChinaClipper's Avatar
ChinaClipper
Hey Jose! Long time no see. I have put around 10K miles on my Goodyear Eagle F1 GS-D3 tires now, running them thru this past DFW winter. They are just outstanding in wet NCT weather - you don't even know that it is raining because of how well these tires track in the wet. I really like them. Compared to the OEM RE040, the GS-D3 is quieter, has much more warning of impending breakaway at the limit, and is more forgiving at the limit on the track. They were (last fall) cheaper than the S03s or T1S, and having gotten 20K from my OEM tires, I expect (based on treadwear so far at 10K miles) to get around 30K with these Eagles -- treadwear being rated at 280-AA-A. If you are running stock rims though, I don't think they are available in the OEM sizes for the fronts.
HTH
Old Feb 24, 2004 | 10:55 AM
The Brickyard Rat's Avatar
The Brickyard Rat
http://www.tirerack.com/tires/surveyresults/max.jsp
Old Feb 24, 2004 | 10:57 AM
The Brickyard Rat
What Clipper says about the Goodyear fronts is true. Anyone know if Goodyear will make the tire in the right size for front stock wheels?
Old Feb 24, 2004 | 01:46 PM
tylerdurden's Avatar
tylerdurden
I ran P-zero Neros on an M3 for a year before I sold the car. They were outstanding. Never drove in snow. I don't believe they were made for that. I can't compare to the new Goodyears because I have not owned them. The only complaint is price. The Rossos don't come close to the Neros. I wasn't aware that they came in the Z sizes.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
