Need to know if will fit the Z
Old May 15, 2020 | 07:48 AM
mariocesar's Avatar
mariocesar
5 Year Member
Default Need to know if will fit the Z
Hello I'm about to buy this set of ESR SR08, specs are, 18x9.5" +15 fronts and 18x10.5" +15 rears. is a 2004 350Z with original set of brakes.
Thanks
Mario.
Old May 15, 2020 | 09:10 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Thanks
Mario.
Should fit, depending on tires and ride height. May need to roll rear guards.
Old May 15, 2020 | 09:25 AM
mariocesar's Avatar
mariocesar
5 Year Member
Thanks, what about if specs change to , 18x9.5" +22 fronts and 18x10.5" +22 rears. still need to roll rear guards?
Thanks
Old May 15, 2020 | 11:26 AM
MicVelo's Avatar
Thanks
Most likely not. I ran +22, +23 (and everything else nearby down to +18) and it was only when I ran 9.5 +15 (F&R) did it bump slightly. (Just on pot holes and speed bumps)
If you run them with a maximum of 255/40F and 275/40R, you should have no problems, even conservatively lowered.
Of course, there will be those that say you can run 11"+ with 0 or negative camber.... and you can!! If you camber them way outside of spec. Hmmmm, not.
Old May 18, 2020 | 08:59 AM
mariocesar's Avatar
mariocesar
5 Year Member
Thanks for the response, kind of confuse so if I run using 255/40F and 275/40R will be no problem with 15 offset?
Thanks.
Old May 18, 2020 | 09:41 AM
MicVelo's Avatar
Thanks.
Like I said, with +15 offset and those tire n' wheel sizes, you will 90% likely need to roll the guards.
With +22 offset and those tire/wheel sizes, 90% likely NOT need to roll.
With 255 fronts, you MIGHT also need to cut the fender liner screw at top.
You'll notice I say "might" and "maybe" a lot (along with "90%")... that's because nothing is absolute. Different cars behave differently depending on age, type of equipment, etc. Giving you pretty good, if general, answer to the question of fitment.
dreamspeed
Jan 1, 2017 04:10 AM
costilla
Nov 7, 2008 10:27 PM
jaaf
Apr 18, 2008 05:19 PM
Zoom750
Jan 15, 2008 10:27 AM
knight_white99
Oct 22, 2005 06:21 PM
