18x9 +15 Tires on 350z
Old Jun 11, 2020 | 03:40 PM
350pleaZ's Avatar
350pleaZ
Question 18x9 +15 Tires on 350z
Just picked up a set of 4 rear 370z wheels (18x9 +15) for CHEAP. 2 tires are trashed and 2 are pretty fresh with 245/45/18. I am trying to keep a good enough ratio to not set off the VDC. I would ideally like to put the current 245/45/18's on the rear so I guess that would make the fronts 225/45/18? But I hesitate to stretch 225's over a 9 inch wheel. Would a 235/45/18 or 245/40/18 be within the ratio to not set off VDC?
I'm still figuring out tire sizes/stagger ratios so forgive me if these are dumb questions. I found it difficult to find much information on 18x9 wheels. I am guessing I will need to roll the fenders a bit, especially the fronts but hopefully I wont have to pull them. Currently on stock suspension but will eventually lower.
PS: passing along a PSA: 370z wheels REQUIRE 370z "shank style" lug nuts.
Old Jun 11, 2020 | 04:22 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
  • 245/40-18 Front
  • 245/45-18 ReaR
Same OEM ~3% VDC ratio
Old Jun 11, 2020 | 05:20 PM
350pleaZ's Avatar
350pleaZ
Thank you @MicVelo.
Old Jun 16, 2020 | 09:08 PM
350pleaZ's Avatar
350pleaZ
Should I pull the front fenders and/or roll the rears with this setup?
​​​​​​Posted more clearly...
​​​​Front: 18x9 +15 | 245/40/15
Rear: 18x9 +15 | 245/45/15
Stock height for now. Planning on lowering an inch in the future.
Old Jun 16, 2020 | 11:25 PM
terrasmak's Avatar
no, nothing needed
Old Jun 18, 2020 | 05:43 PM
Spike100's Avatar
Spike100
You are no where needing a "fender roll,"
Old Oct 30, 2020 | 01:01 PM
350pleaZ's Avatar
350pleaZ
$350 for the wheels. $80 to swap TPMS and 2 tires from old set. Ended up selling the old rims/tires for $250. Not my favorite look but can't beat the price.
Last day in LA photo shoot
More lower? .5" drop in rear already.
What if La Mans Sunset?
spartikus1975
Wheels Tires
Oct 18, 2017 12:52 PM
bahumat2jz
Wheels Tires
Sep 24, 2011 02:19 AM
The Brickyard Rat
Jul 11, 2005 01:54 PM
