350z rims on a heavier car
Old Jun 29, 2020 | 10:42 PM
cat007's Avatar
cat007
Default 350z rims on a heavier car
Hi all.
I'm looking to put some 18X8" 350Z rims - and wanting to run them on an FGX Falcon which is obviously a much heavier car.
Will they be ok with the extra weight?
Also looking to run larger than 245 tyres - hoping for 265's but maybe 265's might be too large? 245's are the norm for 8" rims - anyone put bigger on these rims without issue?
Using them for circuit/track play.
Cheers!
Hunt
Old Jun 29, 2020 | 11:31 PM
bealljk's Avatar
bealljk
how heavy is the Falcon?
Old Jun 30, 2020 | 01:09 AM
cat007's Avatar
cat007
1730kg on file, without me. Not sure if that's with a tank of fuel or not....
Old Jun 30, 2020 | 06:07 AM
KornerCarver's Avatar
KornerCarver
I ran my 17" 350Z wheels on a Dodge Caravan a few years ago.
Old Jun 30, 2020 | 06:42 AM
bealljk's Avatar
bealljk
Interesting how the numbers play out … but my GVWR (gross vehicle weight as defined here https://en.wikipedia.org/wiki/Gross_..._weight_rating) is 3815lbs which is right at 1730kg coincidently.
It's a judgement call - but if you're vehicle is, all in, is around 1730kg than you're probably ok.
Old Jun 30, 2020 | 07:17 AM
iideadeyeii's Avatar
iideadeyeii
I run 275's on these wheels on the rear. No problem running 265's and no problem with the weight
Old Jun 30, 2020 | 11:59 AM
cat007's Avatar
cat007
Thanks for the replies.
Apparently the weight with a full tank of fuel is 1730kg/3800lb. So I guess not that much more than a 350z as some models weigh in at 1630kg/3500lb?
Should be fine I would think.
I'm getting conflicting info that the rims are 18x8 front and 18x9 rear standard - yet the set that I'm looking to buy are all 18x8. Maybe the set I'm looking at are off 2 different cars?
Can anyone confirm if the above stock rims are all 8" wide or are the rears supposed to be 9"?
Cheers!
Hunt
Old Jun 30, 2020 | 12:30 PM
iideadeyeii
The ones you posted are all 18x8 30et
Old Jul 2, 2020 | 04:15 AM
260DET's Avatar
260DET
Wheels are coded for their weight carrying capacity so there should be a marking on the wheel, that's all I know.
Asian Invasian
Sep 8, 2009 03:18 PM
Diesel350
May 13, 2008 07:02 AM
Yellow350Z
Mar 28, 2005 07:51 PM
claymann
Apr 7, 2003 04:54 PM
