245-40-18 ?
Old Mar 5, 2004 | 04:24 AM
supra crazy's Avatar
supra crazy
Default 245-40-18 ?
i was wondering if i put 245 40 on my rear track rims they are would it interfear with the TSC because the tires in that size are alot cheaper than 265 35 and that is the only size up from the 245s
thanks
Old Mar 5, 2004 | 04:33 AM
westpak's Avatar
westpak
SFZCC
You can get 255.
I have 245/45/18 and 255/45/18.
Next time I will go with 40 profile to reduce sidewall height.
Other configurations I have seen here are 245/40/18 with 255/45/18 or 245/40/18 with 255/40/18
Old Mar 5, 2004 | 05:36 AM
supra crazy
i only need new rear tires and kumho only has 245 40 and then it goes up to 265 35. this is from tirerack.com does do you know where i can get kumhos any where else on the internet?
PS where is the dyno located at tommorow and what time does it start?
Old Mar 5, 2004 | 06:28 AM
westpak's Avatar
westpak
SFZCC
Sorry, if it is the MX then it only comes in 245 or 265, the 265/35 would really reduce your overall diameter too much and your speedo will be off, not sure what your fronts are so I can't tell if the front to rear difference will affect anything.
As for the Dyno go here for more info http://www.sfzcc.com/forum/viewtopic.php?t=297 I have only been sending updates to those that emailed me, but we will start at 10 am let me know if you are going email me at gusm@sfzcc.com so far I have 22 cars and wanted to limit it to 25 so don't want too many more or surprise drop ins, I would like to finish at a decent hour so we can go get a bite to eat afterwards.
It will be pretty cool as there will be 16 350Z's (17 if you come) so it will be a nice comparison of various moded cars.
Old Mar 5, 2004 | 08:22 AM
ares's Avatar
ares
Veteran
Id choose a different tire then. or get 265/40 if thats an option.
245/40 isnt so great either, its not wider than the stock tread, only shorter.
you really want/need 245/45 255/45 265/40 IMO.
Old Mar 5, 2004 | 08:33 AM
mcclaskz's Avatar
mcclaskz
Actually, 275/40 is the best option. Check out this link for tire size calculator www.miata.net/garage/tirecalc.html My street tires are 245/40 fronts w/ 275/40 rears. The % are very close to stock. I know other road racers on this forum have used 245/40 all around and have had no problems. This will be my TT set up with 245/40 Toyo RA1s.
Old Mar 5, 2004 | 09:09 AM
lowrider's Avatar
lowrider
275/40 is the right size, but too wide for the track rims. IMO, the best choice is 255/45/18 for the rear and 245/40/18 in front.
Lou
bad boyz
Wheels Tires
Jan 21, 2015 09:48 PM
BawlZTT
Aug 25, 2006 05:40 PM
