Tire pressure for stock 17" wheels?
Old Mar 9, 2004 | 01:50 PM
jikman01's Avatar
jikman01
Default Tire pressure for stock 17" wheels?
Anyone know what the recommended setting should be for the stock 17" wheels? I have an enthusiast model and it currently has 33PSI on the fronts and 28 PSI on the rears, is that OK?
The wheel itself only tells you the max PSI and there's nothing in the door jam that tells you the recommended tire pressure like other cars that i've owned.
Old Mar 9, 2004 | 03:08 PM
Bertg's Avatar
Bertg
There should be a sticker on the drivers side door jamb showing the tire size and recommended pressure. It's 35 psi for the Enthusiast 17" wheels. That makes the ride a little to harsh for my taste, so I set them to 32 all the way around.
Old Mar 10, 2004 | 06:50 AM
gibbsy1's Avatar
gibbsy1
Charter Member #33
Sticker is inside the cupholder cubbie thing in between the seats. Flip up and there you go.
Old Mar 10, 2004 | 04:49 PM
jikman01's Avatar
jikman01
Aaha!!! I looked all up and down the door jam and nuttin!
Thanks for the tip, I will look there.
Old Mar 11, 2004 | 06:45 AM
OZ-Z's Avatar
OZ-Z
Default Its in the cup holder/compartmant under door lid
look under the door between seats in console 35lbs
Old Mar 11, 2004 | 06:04 PM
johnsZ's Avatar
johnsZ
well, this is an interesting point
the label says 35 lbs, but the tires say up to 44lbs is OK (check the fine print near the rim), but the safety warning says do not seat above 40lbs, hmmmmmmmm
I like running about 40 lbs- when i used 35lbs, the outside edges wore badly
MAsSIVrOOM
Oct 20, 2023 10:50 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
