What size spacer?
Old Mar 16, 2004 | 07:44 AM
bigern1970's Avatar
bigern1970
Default What size spacer?
Im running 20 inch axis mods 20X9 +37mm front and rear, I have Falken 255-35-20 , But I want to bring there rear wheels out flush with the rear fenders, does anyone know what size HR spacer I should use, any info would be helpful thanks. Ernie
Old Mar 16, 2004 | 11:11 AM
GoSooners's Avatar
GoSooners
Default Re: What size spacer?
I used to have the Axis Se7en Mods in 19". I used a 20mm for the rear but my wheel width was 8". I think a 15mm or 20mm would work. 25mm may cause it to stick out.
Old Mar 16, 2004 | 01:55 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
The outside diameter of the tire sidewall is usually the widest point of your tire and wheel package. Place a straight edge flush with the face of the tire, and using a ruler measure from the straight edge to the inside lip of the fender as show in image
H&R Trak Wheel Spacers
Old Mar 16, 2004 | 03:05 PM
bigern1970's Avatar
bigern1970
Default Re: Re: What size spacer?
Old Mar 16, 2004 | 03:06 PM
bigern1970's Avatar
bigern1970
Did you have to roll the lip and do you know what the offset was? thanks
Old Mar 16, 2004 | 03:57 PM
GoSooners's Avatar
GoSooners
Default Re: Re: Re: What size spacer?
I didn't have to roll the lip. My offset was a +40. With a 25mm out back, the corrected offset would be +15.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
