Will 9.5" front and 10.5 rears fit???
Old Apr 13, 2004 | 03:40 PM
sschmuve's Avatar
sschmuve
Default Will 9.5" front and 10.5 rears fit???
I wish the search worked. I'm looking at Volk Sf-Winnings 19*9.5 fronts and 19*10.5 rears. I have Eibachs installed, and need reassurance that these will fit without rubbing. 9.5 seems a little wide for the front. Is anybody else running with these sizes. Thanks.
Old Apr 13, 2004 | 03:49 PM
Trent@MVP's Avatar
Trent@MVP
The Challenge's I sell for the Z are a 8.5 up front and 9.5 in rear. I've seen plenty of people fit the 9.5 and 10.5 in there, but depending on what you might do with the car in the future with brakes, suspension, body, etc, we would rather go a little more conservative on the width unless you are absolutely dead set on that wheel size. Do you know what offset they are by any chance?
Old Apr 13, 2004 | 03:53 PM
sschmuve's Avatar
sschmuve
No, but I'll find out tomorrow.
Old Apr 13, 2004 | 10:22 PM
shinz's Avatar
shinz
The eibachs are a 1 inch drop correct? I think you would need to roll the fenders with that setup.
Old Apr 14, 2004 | 02:32 AM
zillinois's Avatar
zillinois
Check out the Unofficial Rim Size/Offset thread in this section. It shows pictures of cars with their rim sizes and offsets. You don't have to roll a 10.5 with the right offset and no lowering.
Unofficial Offset thread
Old Apr 14, 2004 | 06:17 AM
shinz's Avatar
shinz
He already has the eibachs installed. Anyone out there w/ eibachs and 10.5 in the rear w/o rubbing?
Old Apr 14, 2004 | 07:25 AM
speedform's Avatar
speedform
Nope. You will have to roll the rear fender flanges a little if your car is lowered and your running a 10.5" rear wheel. It's not that difficult really.
Old Apr 14, 2004 | 12:11 PM
sschmuve's Avatar
sschmuve
I called 350zonlinestore, and Brian is positive that they will fit without rolling the fenders. He said the offsets are 19f and 29r, with 245/35 and 275/35 tires. I'll keep my fingers crossed.
Old Apr 15, 2004 | 05:47 AM
FriscoRays's Avatar
FriscoRays
I have Eibach springs with 19 x 10.5 wheel +43 offset. Tires are 275/35/19. No fender modification necessary. No rub.
Old Apr 15, 2004 | 06:49 AM
zillinois's Avatar
zillinois
Do you, by any chance, have a 1/2" clearance on the fender side? I have 10.5's with a 30 offset and was wondering if I have to roll.
Old Apr 15, 2004 | 07:52 AM
drew703's Avatar
drew703
I'm running 19x9.5 +22 front 19x10.5 +22 rear, with 245/35/19 and 275/35/19 Toyo T1-S' and I have espelir springs (about a 1.5" drop) And I did not need to roll fenders, nor do I have any rub.
Old Apr 15, 2004 | 08:18 AM
speedform's Avatar
speedform
Wow. Not that I don't believe you but everyone I've ran into who's running a 10.5" rear with 22 offset on a 1" or lower drop has had a rubbing problem, including myself. Is the factory trimming the flanges on '04MY or something?
Old Apr 15, 2004 | 09:53 AM
Topics II's Avatar
Topics II
Just roll the fenders!!! (or shave em) itll look 10times better than just sinking the wheels into the fenderwells.
P.S. i run 18x10 +5 front and rear with like 3" of drop or so. only the rear is rolled, and i wanna shove a 5mm spacer in there to bring the tire snug up to the fender. (however the tires are 225/40 and 245/40 )
Old Apr 15, 2004 | 01:43 PM
350zya's Avatar
350zya
how did you get your car lowered 3 inches>>>??
Old Apr 15, 2004 | 03:09 PM
Strife350z's Avatar
Strife350z
and a 225 on a 10 inch tire?
just my opinion, but sounds like bs to me
Old Apr 16, 2004 | 02:01 AM
ZRAYGO's Avatar
ZRAYGO
yes it will fit.
Old Apr 16, 2004 | 09:50 PM
Topics II's Avatar
Topics II
I got a pic here somewhere... put it this way... my ings side skirts were draggin on the ground during d1 coming off the big bank at irwindale... thats how low it was, then i had to raise it up cuz the sideskirt bottom seperated from the sides...
and yes, i run a 225 on 10 up front.
Old Apr 16, 2004 | 11:23 PM
AmyCroft's Avatar
AmyCroft
er .. It's like this TopicsII is a Drift Car Racer from Signal Racing..
His car has NO 3.5 VQ35DE - It has a SR20DET ( about 475 Hp )
So much lighter - that you must exclude his Car - And his post..
The man has no fear on the track...
And a hell of a nice guy.
Cheers Amy -
Old Apr 17, 2004 | 03:55 PM
nis350z's Avatar
nis350z
let us know how it works out.
Old Apr 20, 2004 | 04:10 PM
pricanz's Avatar
pricanz
Question
can anyone help with this?
Im planning on buying these:
HREs 543
2 10.5x18 and 2 9.5x18 with 2 285/30/18 and 2 255/35/18 tires.... the tires are Falken GR Beta FK-451's the offset is negative 6 in the rear
will these work on the 350 with eibachs?
thanks in advance
Jose
