ABS, TCS Problems, with tires different diameter from stock?
Old Apr 19, 2004 | 10:26 AM
downforce's Avatar
downforce
Question ABS, TCS Problems, with tires different diameter from stock?
Anyone experienced problems with ABS or TCS because of tires that are different in diameter than stock?
I've seen others that have used front and rear tires that are the same in diameter, that is what i want to do, but not if it is going to screw up ABS or TCS.
thanks!
Old Apr 19, 2004 | 11:32 PM
D'oh's Avatar
D'oh
I have 265/35-18 all around for race tires, and have not had VDC/TCS activate unexpectedly. Not sure if they still work correctly though, since I haven't ever activated VDC/TCS with race tires on the street through aggressive driving (and I turn off VDC when AutoXing).
-D'oh!
Old Apr 20, 2004 | 08:55 AM
zturtle's Avatar
zturtle
It will not mess up ABS, or the TCS function of VDC. BUT, it will mess up VDC readings, and will cause the VDC indicator to light up. Basically VDC will not function if you are too far out of spec. No biggie there.
Old Apr 20, 2004 | 12:42 PM
fresno350's Avatar
fresno350
so if i put on 20x9 and 20x10 tires should i always drive with vdc off? or will it still operate normally? thanks
Old Apr 21, 2004 | 06:38 AM
zturtle's Avatar
zturtle
If it is on, in certain situations, you will get an alarm indicator and that is it.
You won;t hurt anything, you are just disabling certain functions.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
