How to reset Tire Pressure Sensors?
I had a flat tire and when I put it back on, the front and rear were swapped on the display. I would like to put the front reading on the front display and rear on rear display. Does anyone know how to do this without a consult II?
Originally posted by zipman
let the tire pressure cool down to reg temp,then take off the tires and the remount the tires this should reset your sensors
I don't want to take the car back to the dealer since he will charge me.
The only reason I noticed TPS where being displayed wrong is because the rear tire I had repaired only had 30 psi. The rest of my tires had 35 psi and my display showed the 30 psi on the front not rear. So I lowered other rear tire to 30 psi and both tire pressures for the rear were displayed on the front.
