Nismo Wheels + TPS problems
I just had my Nismo rims put on. Well now the TPS is measurng about 4-5 PSI low (as compared to another pressure gauge). I also have the low tire pressure dash light on continually. Can anyone tell me how to reset this? Anyone else have the same problem? Any help would be greatly appreciated. Thanks.
First, I'd make sure that the TPS sensors were put back on the right tires (by adjusting the pressure in each tire and comparing it against what the monitor says.)
If they are in the wrong place, a Nissan dealer can reset the system (relearn the locations of the sensors) with a CONSULT-II scanner.
If they are in the right place, but reading the wrong pressure, then they were probably damaged in the rim-swap. Are all four reading low?
Yes, all four are reading low by ~4-5 psi. Maybe they were damaged, but I don't think they were because they all are consistant with each other (all reading low). The rear reads a little lower than the fronts when set at the same pressure.
