SOB! new 19s... now pulling to the right
Old May 27, 2004 | 06:43 PM
Strife350z's Avatar
Strife350z
Default SOB! new 19s... now pulling to the right
Anyone else experiencing this?
My Z on stock 18s didn't pull... when I was running my 16" winters, it didn't pull... but now that I've got 19s, the car pulls to the right like a ****!
I suspect it's the larger contact patch with my 245/35/19s
anyway... do I/we still qualify for the TSB? or do the new rims/tires exclude me from it?
Old May 27, 2004 | 08:18 PM
twenzel's Avatar
twenzel
I think it just depends on your VIN #. At least they can do the alignment process.
Old May 27, 2004 | 11:16 PM
mgl's Avatar
mgl
i don't think nissan will cover you, since you have aftermarket rims and tires. i think the only rims/wheel they cover for alignment is the stockies and the nismos.
maybe you can have your wheels rebalanced and also check the air pressure. not sure if this will help, but is worth a shot.
Old May 28, 2004 | 04:06 PM
dnguyent's Avatar
dnguyent
That is strange...makes no sense.
Something must have happened to your alignment right before or after installing the 19's. Did you install the wheels yourself, or did someone else do it, and take it for a "test drive"?
Old May 28, 2004 | 09:04 PM
Strife350z's Avatar
Strife350z
hey guys... thanks for the input
actually the strange thing is, I did an alignment right after I installed my wheels, and nope I didn't install them myself, had it done at a shop... oh and the pulling actually got WORSE after the alignment!
I saw the specs though and they look right...?
besides, isn't the pull to the right TSB a change on the control arm bushing and not an alignment?
Old May 28, 2004 | 09:07 PM
adanande's Avatar
adanande
do you still have you old rims? install them back and see if it still pulls if it still does go to the dealer and have them align it and check it out. Its up to you whether you tell them that you have had 19s on the car or that you have had another shop align it. Also i am assuming that you still have you alignment warrantee, if not factory 4 wheel alignment is a 150 dollars. Ouch!
Old May 29, 2004 | 04:04 PM
lemieux's Avatar
lemieux
thats funny i had the pull before i had my 19" volks on and now they are on the pull went away. opposite effect as you thats weird.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
