How much more susceptible to damage are 19" wheels?
Old Jun 16, 2004 | 12:14 AM
heatmiser's Avatar
heatmiser
Default How much more susceptible to damage are 19" wheels?
I really like the look of 19" wheels but am concerned that they will damage easily. Any input from people who have had them on their Z for some time would be greatly appreciated.
Old Jun 16, 2004 | 01:27 AM
joust75's Avatar
joust75
I have hit some prety bad ruts and I have no probs. I have TE37 forged 19*8.5 front and 19*9.5 rear.
I was concerned like you so I went 255/35 19 front with the 275/35 rear. The 255/35 looks just as good as the 245/35 setup and gives a little taller sidewall and more sidewall protection from the width. No prob from VDC either. My next set of tires I will bump up the rears some more to 285/35
Get yourself some forged 19s, run my tire and wheel setup and you wont have to worry.
Unless you live in Mexico.
Old Jun 17, 2004 | 04:58 AM
tommy81569's Avatar
tommy81569
Joust 75,
What offsets are you running? I'm debating the same rims and tire sizes and want to make sure I get the right offsets.
Old Jun 17, 2004 | 05:05 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Zero problems with my 19" GT-7s. I've always done what I could to avoid major potholes and such, but sometimes I just have to drive over them and the wheels are fine.
Old Jun 17, 2004 | 03:11 PM
HaNkYs_Z's Avatar
HaNkYs_Z
longest you check your tires psi often, make sure you tires are not flat, then you should be fine.
Old Jun 17, 2004 | 03:28 PM
joust75's Avatar
joust75
Originally posted by tommy81569
Joust 75,
I run 19/8.5 +29 front 19/9.5 +34 rear. These offsets give the TE37s flat spokes and a two inch lip on the rear. If you got + 22 all around with these sizes you would have concave spokes but no lip on the rear.
Hope dis helps.
Old Jun 21, 2004 | 06:53 AM
Speedracer's Avatar
Speedracer
Default Depends on where you live.....
If you live where roads are generally smooth, go 19", but if roads are choppy, 18 is better for the car, wheels, and your butt.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
