Question on running 19x9.5 Frt & 19x10.5 Rear.Also what tires would best suit.
Old Jun 20, 2004 | 05:38 PM
nexstage350's Avatar
nexstage350
Question Question on running 19x9.5 Frt & 19x10.5 Rear.Also what tires would best suit.
hey fellas! couple of questions if anyone can help me out with.
i want to run 19x9.5 in the front. is there any rubbing that is involved in the front? i plan on lowering the ride too. so how low should i drop it keeping it safe? and what would be tire size i should use?
second thing is the rear? any problems of rubbing? will they hit the fender wall cuz it's big? and what would be the best size tire i should run for the rears?
if anyone can help me out or give me some advise i will be so thankful. thanks again..
Old Jun 20, 2004 | 09:34 PM
hido7's Avatar
hido7
Default Re: Question on running 19x9.5 Frt & 19x10.5 Rear.Also what tires would best suit.
Did you order the rims ? What brand of rims you are looking?
I order my Iforge with 19x9.5 and 19x10.5, and my tires are 295/35/19 and 255/35/19. I'm still waitting my rims, so couldn't tell you the result.
Old Jun 20, 2004 | 10:39 PM
papag1's Avatar
papag1
19's should be fine. Don't get such a big drop cuz you may rub on turns or bumps steep driveways etc. I went with the Espelir springs. They are perfect .9 inch drop my recomendation
Old Jun 21, 2004 | 08:13 AM
nexstage350
hey thanks for the info. what size tires r u runnin?
Old Jun 21, 2004 | 08:19 AM
nexstage350
Default Re: Re: Question on running 19x9.5 Frt & 19x10.5 Rear.Also what tires would best suit.
hey thanks or the info. let me know how it all works out.
Old Jun 22, 2004 | 11:03 AM
nexstage350
BUMP. is there anyone that could me out? thanks
Old Jun 22, 2004 | 11:58 AM
JimRHIT's Avatar
JimRHIT
it depends on the wheels and the offsets .... look at that thread ... it will answer all your questions
bcoffee20
Nov 19, 2015 06:39 PM
rizzla
Sep 29, 2015 03:58 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
slimjim888
Mid-Atlantic Marketplace
Sep 9, 2015 06:07 AM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
