Do you guys think 19x9.5 all around will work?
Old Jun 23, 2004 | 03:34 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Default Do you guys think 19x9.5 all around will work?
I like to know if 19x9.5 all around will work on the Z without any problems or not, like VDC?
Old Jun 23, 2004 | 08:29 PM
PhoenixINX's Avatar
PhoenixINX
Yes... will work fine. Just watch for rubbing in the front and rear. Roll the lip accordingly.
Old Jun 23, 2004 | 08:34 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Do you think I need to roll my front fenders if I go with 19x9.5 +22? and how will the handling be compare to 19x8.5? any difference?
Old Jun 23, 2004 | 10:07 PM
Rayden2001's Avatar
Rayden2001
You will not need to roll the fronts if you either go with a lower profile tire or you can use the same tires you have on your 8.5s and stretch it on the 9.5s. I'm going with 19x9.5s in the fronts too with 245/30/19 rubber. The handling is better with wider wheels in front.
Old Jun 24, 2004 | 09:06 AM
RIVET's Avatar
RIVET
Default aesthetically unpleasing
I've seen this done and it looks.....well, crappy. The Z/G needs staggard wheel widths (i.e 9.5/10.5) or the rears look wrong.
Old Jun 24, 2004 | 09:14 AM
Rayden2001's Avatar
Rayden2001
Default Re: aesthetically unpleasing
Only if the offset is the same. Then it looks tacky
Old Jun 24, 2004 | 10:26 AM
HaNkYs_Z's Avatar
HaNkYs_Z
if I do this, the offsetswill be 19x9.5 +22 front and 19x9.5 +12 rear. I am still thinking if I should do it or not.
Old Jun 24, 2004 | 10:57 AM
tig488's Avatar
tig488
ive got 19x9.5 all around on my G35, got them from a guy who had them on his z, +35 front and +22 rear, running 275/35s all around without any problems or rubbing.
Old Jun 24, 2004 | 12:02 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Can you take some pictures for me and post on here? I like to see how it look, thanks.
Old Jun 24, 2004 | 02:55 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why would you do this though (unless someone has the wheels laying around)?. The staggered widths are FAR easier to get a hold of than staggered offsets.
Old Jun 24, 2004 | 03:09 PM
Rayden2001's Avatar
Rayden2001
yep.. very true.
Old Jun 24, 2004 | 08:27 PM
cpoe52's Avatar
cpoe52
tig488:
Do you have any problems with the TCS/VDC?
Does it work like it did with your stock wheels/tires?
Thanks...
Old Jun 24, 2004 | 08:36 PM
HaNkYs_Z's Avatar
HaNkYs_Z
B/c I saw this guy posted in private classified section that is selling only 2 19x9.5 +22 for cheap and I was thinking about getting that and make my more looks concave too, just like going with 19x9.5 n 19x10.5 +22 all around except me r 19x9.5 +12 rear. What do you guys think? or should I stay with my 19x8.5 +29?
Old Jun 25, 2004 | 05:24 PM
tig488's Avatar
tig488
i did it because i bought them from somebody, if i had it to do over again id go with 10.5s +12 in the rear for a fat lip, and no i havent had any problems with vds, tcs.
Old Jan 3, 2005 | 02:44 PM
apr01's Avatar
apr01
I have a newbie question about all of this. If the stock 18" wheel offset is the same (30 F/R), why would you have to have different offsets F/R with new rims of the same size all around?
I like the Enkei PK-6 18x9.5, and I was thinking of putting these all around. Any comments, suggestions?
thanks,
Aaron
Old Jan 3, 2005 | 03:10 PM
orhanz33's Avatar
orhanz33
sport compact car got better results w/ a non staggered setup, 274/40/18 front and rear (18x9 bbs wheels i think) and pulled a 1.0 lateral g!! also going w/ a non staggered setup may might eliminate the understeer
i was going to post a thread asking for people who have had both staggered and non staggered setup to give some input, but i figured i'd do a search first
p.s. 245's on a 9.5" wheel will probably fit, but will be stretched as hell... and the contact patch will not be any different then if you were to go w/ a 8.5" wheel w/ the recommended 245 width
Miguel Albanez
Oct 17, 2022 10:13 AM
Dr.Paulyy
Jul 29, 2019 07:45 AM
Shane86
Sep 17, 2015 05:33 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
