Big wheels 20'' GTC 19'' 5ZR *56k good luck*
Old Jul 7, 2004 | 01:11 PM
BobbyBoy's Avatar
BobbyBoy
Default Big wheels 20'' GTC 19'' 5ZR *56k good luck*
Here are some pics of customer cars that we have worked on the last couple of days at AutoRnD
Volk GTC 20x9.5+20 F 20x10.5+22
Did not roll fenders on the car no rubbing, but didn't push it under extreme cornering and steering angles to see if it would rub in extreme conditions.
Next is 5zigen 5ZR 19x8.5+33 19x9.5+31
Also installed are Zeal V6 coilovers
If you have any fitment/offset questions feel free to chat it up, we make aggressive fitment wheels happen
408-635-0000
Old Jul 7, 2004 | 08:58 PM
MY350Z.COM's Avatar
Those look great.
BTW AntoRnD is a sponsor on this site.
http://www.autornd.com
They have some really cool/blue brakes.
Old Jul 7, 2004 | 09:45 PM
___DJK___'s Avatar
___DJK___
Wow! What kind of camera did you use to take those pictures? They came out phenominal!!!!
Old Jul 8, 2004 | 03:02 AM
Z_city's Avatar
Z_city
What kind of carbon fiber hood is on the first car?
Old Jul 8, 2004 | 05:21 AM
MRJDMZ33's Avatar
MRJDMZ33
I might sell my 19inch Volk SF Challenge wheels and get the 20inch GTC's. Do you mind asking me how much did the 20inch GTC's come out to??? Just the wheels alone without tires. I want the same sizes and offsets that are shown above on the sunset Z. I would very much appreciate it. Thanks
Old Jul 8, 2004 | 06:04 AM
03Brickyard's Avatar
03Brickyard
What front lip is that on the orange car???
Old Jul 8, 2004 | 08:09 AM
BobbyBoy's Avatar
BobbyBoy
On the orange car is the C-West front lip, and Kaminari Hood.
I Use a Canon S45 with some preset settings for indoor and outdoor for those pics.
MRJDMZ33 Check your PM
Old Jul 8, 2004 | 10:04 AM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
MRJDMZ33, did you install your TPS on your SF Challenge?
Old Jul 8, 2004 | 10:12 AM
MRJDMZ33's Avatar
MRJDMZ33
No I did not...I disconnected them.
Old Jul 8, 2004 | 10:15 AM
cquence 350 [Z]
how did you disconnect them? is it very easy to do? shops charging me like 200 bucks to swap the sensors on my SF Challenge.
Old Jul 8, 2004 | 10:25 AM
zxsaint's Avatar
zxsaint
Fairlady Stalker
the 20" gtc's look absolutely amazing -- but I can't imagine how heavy they must be since they seem to be the heaviest in the volk lineup.
Old Jul 8, 2004 | 10:30 AM
MRJDMZ33's Avatar
MRJDMZ33
Noway man...All you do is take off the Touring wheels and put your new set of wheels on, and that's it. That's the way the TPS is disconnected. Then when you sit in your car and go to where your TPS is supposed to read on your middle dash gauges, it will simply read nothing.
MRJDMZ33's Avatar
MRJDMZ33
Noway man...All you do is take off the Touring wheels and put your new set of wheels on, and that's it. That's the way the TPS is disconnected automatically. Then when you sit in your car and go to where your TPS is supposed to read on your middle dash gauges, it will simply read nothing.
Old Jul 8, 2004 | 10:37 AM
cquence 350 [Z]
Well I just found a shop that will install my TPS sensors for like 25 bucks each will. Should I just do it?
Old Jul 8, 2004 | 10:40 AM
myz8a4re's Avatar
myz8a4re
just out of curousity im wonderin if heavier offsets are available for the zigen 5zr wheels. it seems to me that 10mm heavier offset wheels would have a much more aggressive appearance than the offsets on the wheels in the pics. those offsets are too close to stock & the only saving grace there seems to be the wider wheel widths. i know my statement is very opinionated but i know im not the only one that feels this way. i went 15mm & 20mm on my milanos to get that aggressive look, even wish they offered a more aggressive offset than that for the rear personally.........does zigen not offer heavier offsets?
thanx,
-justin
Old Jul 8, 2004 | 11:51 AM
BobbyBoy's Avatar
BobbyBoy
The wheel and tires weighed 55lb for the front and 57 lb for the rear
For the 5 zigen 5ZR wheels, the lowest 8.5" width offset is +30
for the 9.5" it is +13 but we went with the +31 since the 13 might be too low. I agree with you however, the lack of low 20 offsets with the 8.5 and 9.5 width 5ZRs is upsetting. If you go with the 8, 9, or 10 inch width you can get those better offsets.
Old Jul 8, 2004 | 12:00 PM
myz8a4re's Avatar
myz8a4re
ok i see, thanx for that info. i have the zigen 5zr copse wheels on my 300zxtt. i bought them way back when they 1st came out. i trusted the distributor that i purchased from to sell me the correct offsets for my application sincei was unsure back then. i was a tad displeased since they too were not where i thought they would sit. they still look great but 1/4" more offset would look much better:
much better seen from this angle:
oh well, i learnede from my mistakes...beautiful wheels none the less!
-justin
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dymsi
Sep 29, 2015 11:32 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
samansharif
Sep 25, 2015 12:31 PM
