wheel bearing going bad
Old Jul 25, 2004 | 06:28 PM
booger's Avatar
booger
Default wheel bearing going bad
My driver side front wheel bearing is going bad .I have 15mm spacers [hubcentric ] The dealer is going to fix it under warrenty...but said it was due to the spacers . Any one else have bearings go bad on them....spacers or not ?
Old Jul 29, 2004 | 05:29 PM
Strife350z's Avatar
Strife350z
what do your bad bearings sound like?
Old Jul 29, 2004 | 05:38 PM
booger's Avatar
booger
The dealer replaced the bearing as we both thought it was going bad. But after doing so . I still have the noise when taking a right hand turn . They put it up on a lift and looked and looked . I was the one that actually found it . It was the header touching the steering wheel shaft and you could see where it had been rubbing it . It didnt do it after install of the headers , but has gotten worse since it started about 3 months after headers were put in . Need to check to see if bolts are coming loose or I may have shifted some thing with cat uninstall and test pipe install
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
