F_A_T_T_E_S_T Tires on a 19" rim...????????
Old Oct 7, 2004 | 12:31 PM
  #81
JimRHIT's Avatar
JimRHIT
look forward to the pics
Old Oct 7, 2004 | 12:47 PM
  #82
Zquicksilver's Avatar
Zquicksilver
Thanks for the link Redlinez... You know, they're going to be a lot of copy-cats out there I'd put you right up there with best Redlinez!
MRJDMZ33,
Post those pics! When you take them please get a shot or two of the distance between the fender and the rubber in the rear.
Thanks in advance...
Old Oct 7, 2004 | 01:02 PM
  #83
DrCold's Avatar
DrCold
Originally posted by MRJDMZ33
Well believe it or not, but I just changed my rear tires to the Continental ContiSport Contact 2 sizes 315/25/19's and they fit like a glove in the fender. I also finally aligned the car yesterday as well as rolled in the fenders. I will also be changing the front tires with 275/30/19's. Once my friend this Sat. takes pics of my Z at a spot he found down here in Miami, I will most definitely post them up here.
What off set do you have? I was going to do the 295/30/19's but I was afraid they would be too wide. Hmmm maybe next summer i'll go with 275/30 and 295/30.
Old Oct 7, 2004 | 01:04 PM
  #84
MRJDMZ33's Avatar
MRJDMZ33
MRJDMZ33,
Will do. I'll post up the picks with the distance between the fender and the rubber just like you did on your post...
Old Oct 7, 2004 | 01:10 PM
  #85
MRJDMZ33's Avatar
MRJDMZ33
The offsets for the front are +15 and the rear +23..Believe me when the shop slapped on those 315/25/19's and put them on the car...I was like omg they fit perfect..And now the tires looks and drives even better with the car aligned...The entire patch on the rubber is on the ground...Incredible grip especially last night on the highway when it was pouring down rain over here...I drive felt like it wasn't raing at all...
Old Nov 1, 2004 | 04:30 PM
  #86
Zquicksilver
I got my new wheeeeeeeeelsss...
http://www.350zmotoring.com/forums/s...threadid=16210
Sorry for the redirect, no post without paying some host, my350
Old Nov 2, 2004 | 08:11 AM
  #87
JimRHIT's Avatar
JimRHIT
MRJDM .... where's those pics ?
Old Nov 2, 2004 | 01:49 PM
  #88
symbolic350's Avatar
symbolic350
i running 315 in rear here are some pics http://community.webshots.com/script...umID=208831018
Old Nov 4, 2004 | 08:19 AM
  #89
Zquicksilver
no worky...
Old Nov 4, 2004 | 09:07 AM
  #90
RedZeater's Avatar
RedZeater
no worky...
HUH THATS WEIRD U CAN LOOK OTHER POST "HRES IN WHAT U THINK " SOME PICS POSTED THERE
Old Nov 5, 2004 | 08:48 AM
  #91
revhigh's Avatar
revhigh
I have the pics of the car and if anyone needs them let me know
Old Jan 7, 2005 | 09:33 PM
  #92
sbcbaseball's Avatar
sbcbaseball
Sorry to revive a old thread but Im currently in process of getting new tires for my car. I currently have racing hart cpf-tune 19 inch wheels. Front are 9 inch wide with a +26 and rear are 10.5 with a +22. Im running 245/35/19(toyo) in front and 275/30/19(toyo) in back right now and fenders are rolled (found out later didnt need to be) . My question is could I put 265/30/19(continental2) in front and 315/25/19(continental2) in back and be ok? I do have coil overs on my car and its has about a 1.5 inch drop. Anyone out there with this type of set up the info would be greatfully appreciated.
Old Jan 8, 2005 | 02:20 PM
  #93
sbcbaseball
BUMP.......
Old Jan 8, 2005 | 04:46 PM
  #94
redlinez's Avatar
redlinez
Below is only my opinion, I could be wrong:
Based on my wheels and offsets the fronts should be fine and the rears may be at the limit. Since your fenders are rolled and the tires are so short, maybe no problem.
One board member Karmamag has 295/30 Continentals with a 10.5 and +22, fenders rolled or cut don't remember. His tires are 12.2" wide and the 315's are 12.4".
I believe he's running 255/35's on front which is slightly taller than rear with no TCS/ABS/VDC problems.
Your choices are considerable shorter than the stock tires and the front will be slightly taller than the rear. It looks like your current setup is the same so if your not having TCS/VDC problems maybe you won't with new tires.
There is at least one member running 315's in the rear, don't know his offsets. It's a Redline car and looks great!
I personally would not run this combo, (too short for me !) preferring the 275/295 setup in the Continentals.
Again , just my opinion.
Bob
Old Jan 8, 2005 | 04:58 PM
  #95
redlinez's Avatar
redlinez
Did a search for 315 This is the member symbolic350 and below are some pics.
http://community.webshots.com/photo/...08839006SIURZy
Old Jan 9, 2005 | 09:14 AM
  #96
Import-Tooner's Avatar
Import-Tooner
G35TT was running a 295/45/18 on a 9.5" wheel.
Old Jan 9, 2005 | 08:44 PM
  #97
sbcbaseball
Thanx for info redlinez...man that 315 sure does look nice
Old Jan 10, 2005 | 05:37 PM
  #98
whatever's Avatar
whatever
Veteran
running 275/295 combo. No TCS/ABS/VDC problems.
Old Jan 10, 2005 | 09:49 PM
  #99
sbcbaseball
Very nice,,what size rims are u running and width?
Old Jan 10, 2005 | 09:55 PM
  #100
sbcbaseball
Whatever,
My bad I see u have the size on ur thread.How is the ride ?,I would think its better to launch.With the 245/275 combo I run now it just seems like my tires are constantly slipping when i power up and my z has a few bolt on mods.I wanna make sure i have enough patch on the floor for my future tt set up.
