Upgraded from 17" to 18'' track rays...Spacers needed?
Old Aug 8, 2004 | 09:58 PM
AceJ587's Avatar
AceJ587
Question Upgraded from 17" to 18'' track rays...Spacers needed?
Hey guys, Im kind of a newbie when it comes to wheel offsets and all that Crap. Im just curious if spacers are necessary in my case. I have an Enthusiast, and upgraded to 18" Track Rays. OR are they a direct replacement for the 17"s. Thanks
Old Aug 9, 2004 | 05:28 AM
Audito350Z's Avatar
Audito350Z
direct replacement... no spacers needed
PeteH
Old Aug 9, 2004 | 07:53 AM
AceJ587's Avatar
AceJ587
Thanks Pete.
Old Aug 9, 2004 | 08:07 AM
westpak's Avatar
westpak
SFZCC
Direct replacements, although I was thinking of spacers to being the wheel out a bit to be flush with the fender, but be careful if you lower the car.
Old Aug 9, 2004 | 08:54 AM
AceJ587's Avatar
AceJ587
Im leaving the suspension stock.. That Is a good idea though. What size spacers are you thinking? a Plus offset shouldnt hurt anything should it?
Old Aug 9, 2004 | 09:14 AM
4myZ350's Avatar
4myZ350
my brakes strarted making noise when i did the 17" to 18"rays any body the thats possible????????
Old Aug 9, 2004 | 10:07 AM
AceJ587's Avatar
AceJ587
Yep, Im getting a slight vibration coming from the front brakes as well, after I installed the Rays..Dunno why?
I just thought the Fronts were possibly out of balance.
Old Aug 10, 2004 | 08:57 AM
03Z33's Avatar
03Z33
For best looks a spacer works great... conservative set up is 15mm front and 20mm rear but with some negative camber you can easily fit 20mm front and 25mm in the rear.
Vibration is most likely wheel balance or flatspotted tires.
Brake noise should not be related to wheels, make sure lug nuts are tight.
bcoffee20
Nov 19, 2015 06:39 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
