HKS Hypermax II adjustments. Optimum settings?
Old Feb 1, 2005 | 08:38 PM
spf4000's Avatar
spf4000
Interesting. By running a stiffer front, it only serves to increase the understeer. I'm not sure what kind of tire/wheel combination you're running, but if you're running the stock stagger, I'd recommend softening up your front a bit.
Old Feb 2, 2005 | 06:39 AM
stx's Avatar
stx
Originally posted by jchen1020
No, that is 11 clicks from the firmest.
BTW, yes I know. My click 33 times in front, 42 in rear. But if you read the owner's manual. It tells you. You only count 30 from the firmest point. so 11 clicks from the stiffest would be called 19 clicks. 16 from stiffest would be called 14 clicks. On owner manual, it also tells you not to set it at more than 30 clicks towards left (soft).
Hope this helps you!!!
Thanks! My instructions were in Japanese so I couldn't read them.
Old Feb 2, 2005 | 03:12 PM
jchen1020's Avatar
jchen1020
U R WELCOME!
