Need fenders cut on LI NY
Old Oct 26, 2004 | 01:44 PM
tylerdurden's Avatar
tylerdurden
Default Need fenders cut on LI NY
Anyone know of a shop that will cut or roll fenders on Long Island or NYC area. Fat wheels and tires on the way.
Old Oct 26, 2004 | 03:23 PM
havabooz's Avatar
havabooz
what setup are you gonna run?...any place can prob just cut it ...rolling it is a little harder im assuming because you may suffer from stress in the paint
Old Oct 26, 2004 | 08:23 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
i got a air dremel and went at it...
choppa choppa choppa
Old Oct 27, 2004 | 03:08 AM
mchapman's Avatar
mchapman
Jesus christ Jason, taking up a bit of real estate arent you?
Old Oct 27, 2004 | 07:14 AM
havabooz's Avatar
havabooz
do what he did..just hope it comes out a bit nicer
Old Oct 27, 2004 | 11:20 AM
Zquicksilver's Avatar
Zquicksilver
If and only if I lower I will have to probably cut my fenders. I would cut verse rolling personally. No matter how good you seal it, creating a V cavity in the rim lip/edge will only trap sh*t over time then rust out. I would cut or grind away only what's necessary leaving about a .25" for stregth. That should clear about everything as far as tires.
Right now I don't have to roll and I have 295/35/19 with a +29 offset in the rear. I am at stock height too.
Old Oct 27, 2004 | 01:01 PM
tylerdurden
I'm getting the same set up as Jason at "Performance". I'm getting them from Jason too. Said good bye to my 19' DTM's. Great wheels by the way, just wanted to go back to 18's.
Old Oct 27, 2004 | 09:34 PM
jaxxxx's Avatar
jaxxxx
jason was it that hard to cut? or you think it can be cut a little more straight?
Old Oct 28, 2004 | 06:08 AM
Jason@Performance
Performance Nissan
it can be done alot more straight... when the tech's do it to a customers car they do it perfect...
but by the time I got my wheels back from being M&B I just wented to get them on so did it...
One of these days im going to go in with a different tool and straighten it out and also put on some anti rust stuff...
Your going to love the rims TylerDurden
I dont remember if we talked about it on AIM but the tire diameters are a little shorter then the usual size tires put on the Z, but they do not effect VDC...
The Speedo will be 2% faster.. when you are going 60MPH you will actually be going 58.8MPH
The tire is .2" shorter in the rear then a 275.40.18 or 275.35.19
same in the front...
When I had my Eibach Prokit on my car I dont remember the wheels tucking under in hard cornering... I know I have a few pictures of my car in a corner while I was on the Pro-Kit.. ill have to post them...
Old Oct 28, 2004 | 02:26 PM
tylerdurden
So let's see....when I'm going 146 MPH on the Jones Beach Parkway I'll actually be going.......
Justin100
Nov 25, 2021 06:26 AM
sales@czp
Sep 23, 2019 03:30 PM
Dymsi
Sep 29, 2015 11:32 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
