What offset wheels, front and rear 18x9.5?
Old Nov 15, 2004 | 11:41 AM
002-M-P's Avatar
002-M-P
Default What offset wheels, front and rear 18x9.5?
Who can tell me what offset wheel I need to fit 18x9.5 on the front and rear of my 350Z. I plan on running 265/35-18 tires all the way around. Thanks.
Old Nov 15, 2004 | 09:07 PM
03Z33's Avatar
03Z33
Conservative fittment would be anywhere from 18x9.5 et +20 to +30 front and rear.
You can fit as low as et +12 up front but may want to run a narrower tire (245/40/18).
The rear can fit an 18x9.5 et +5 with anything less than 275/40/18 tire.
Old Nov 16, 2004 | 11:33 AM
vze4fhpv's Avatar
vze4fhpv
Hey guys, I want to run 19x8.5 all the way around. What tire would you suggest? 265/35/19? Is anyone else running same size on all 4? What are the advantages and disadvantages of doing so? The wheels im looking at have a 35mm offset
Old Nov 16, 2004 | 04:15 PM
03Z33's Avatar
03Z33
That setup should work fine. You will notice slightly heavier steering with the wider front tires, and may want to get a power steering cooler (Nismo, Stillen, ARC, etc...) but the handling should be much improved over stock tire sizes.
Also the wheels will stick in the fenders a lot, like stock, so if you're looking for a more aggressive look (tires flush w/fender) then you should get slightly wider wheels, and lower offsets.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Stevo Z
Oct 3, 2015 09:14 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
